| 2/stable | 168 | 24 Sep 2024 | |
| 2/candidate | 168 | 24 Sep 2024 | |
| 2/beta | 168 | 24 Sep 2024 | |
| 2/edge | 307 | Yesterday | |
| 2/edge | 306 | Yesterday |
Charmed OpenSearch Tutorial > 7. Clean up the environment
In this tutorial, we’ve successfully:
- Deployed OpenSearch on LXD
- Enabled TLS
- Integrated with a client application
- Rotated user credentials
- Scaled our deployment
You may now keep your OpenSearch deployment running to continue experimenting or remove it entirely to free up resources on your machine.
Remove Charmed OpenSearch
Warning: When you remove Charmed OpenSearch as shown below, you will lose all the data in your cluster.
To remove Charmed OpenSearch and the model it is hosted on, run this command:
juju destroy-model tutorial --destroy-storage --force --no-wait
The next step is to remove the Juju controller. You can see all of the available controllers by entering juju controllers.
To remove the controller created for this tutorial, enter:
juju destroy-controller opensearch-demo
Then, don’t forget to delete the Juju model configuration file.
rm cloudinit-userdata.yaml
Remove Juju
Warning: When you remove Juju as shown below you will lose access to any other applications you have hosted on Juju.
To remove Juju altogether, enter:
sudo snap remove juju --purge
Remove LXD
Warning: When you remove LXD as shown below you will lose access to any other applications you have hosted on LXD.
You can list all your currently running LXD container with lxc list.
To uninstall Juju, enter:
sudo snap remove lxd --purge
Reset the Kernel parameters
Warning: In the following command, use the values you saved during step 1 → Get default values.
If you did not save those values, use the second reset option.
Leaving the custom kernel parameters outside of this tutorial scope can impact the host machine’s performance.
To reset them, you can either :
- Reboot your computer
- Set your original parameters with the following command :
sudo tee -a /etc/sysctl.conf > /dev/null <<EOT
vm.max_map_count=262144
vm.swappiness=60
net.ipv4.tcp_retries2=15
fs.file-max=1048576
EOT
sudo sysctl -p
What next?
- Check out other charms on charmhub.io
- Report any problems you encountered
- Give us your feedback.
- Contribute to the code base
