| 2/stable | 168 | 24 Sep 2024 | |
| 2/candidate | 168 | 24 Sep 2024 | |
| 2/beta | 168 | 24 Sep 2024 | |
| 2/edge | 294 | 28 Oct 2025 | |
| 2/edge | 293 | 28 Oct 2025 |
All commands are written for juju v.3.1.7+
How to migrate to a new cluster via restore
This is a guide on how to restore a backup that was made from a different cluster, (i.e. cluster migration via restore).
To perform a basic restore (from a local backup), see How to restore a local backup.
Restoring a backup from a previous cluster to a current cluster requires:
- At least 3x Charmed OpenSearch units deployed and running
- Access to an S3-compatible storage
- Configured settings for the S3-compatible storage
- Backups from the previous cluster in your S3-compatible storage
List backups
To view the available backups to restore, use the command list-backups:
juju run opensearch/leader list-backups
Running operation 335 with 1 task
- task 336 on unit-opensearch-0
Waiting for task 336...
backups: |2-
backup-id | backup-status
2024-04-25T21:09:38Z | success
2023-12-08T21:16:26Z | success
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id (from the previously returned list) to the command:
juju run opensearch/leader restore backup-id="2024-04-25T21:16:26Z"
Running operation 339 with 1 task
- task 340 on unit-opensearch-0
Waiting for task 340...
backup-id: "2024-04-25T21:16:26Z"
closed-indices: '{''.opensearch-sap-log-types-config'', ''series_index'', ''.plugins-ml-config''}'
status: Restore is complete
Your backup has been restored.
If the restore takes too long, the Juju CLI above will time out but the juju status command will provide a view if the charm is still running the restore action or not.
