Kafka K8s
- By Canonical Data Platform
3/beta | 56 | 27 Feb 2024 | |
3/edge | 60 | 03 May 2024 |
This is part of the Charmed Kafka Tutorial. Please refer to this page for more information and the overview of the content.
Setup the environment
Multipass is a quick and easy way to launch virtual machines running Ubuntu. It uses “cloud-init” standard to install and configure all the necessary parts automatically.
Let’s install Multipass from Snap and launch a new VM using “charm-dev” cloud-init config:
sudo snap install multipass && \
multipass launch --cpus 4 --memory 8G --disk 30G --name my-vm charm-dev # tune CPU/RAM/HDD accordingly to your needs
Note: all ‘multipass launch’ params are described here.
Multipass list of commands is short and self-explanatory, e.g. show all running VMs:
multipass list
As soon as new VM started, enter inside using:
multipass shell my-vm
Note: if at any point you’d like to leave Multipass VM, enter Ctrl+d
or type exit
All the parts have been pre-installed inside VM already, like MicroK8s, LXD and Juju (the files ‘/var/log/cloud-init.log’ and ‘/var/log/cloud-init-output.log’ contain all low-level installation details). Also, the image already comes with two juju controllers already setup, one for LXD and one for MicroK8s
$ juju list-controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
lxd* tutorial admin superuser localhost/localhost 2 1 none 3.1.5
microk8s - admin superuser microk8s/localhost 1 1 - 3.1.5
Make sure that you use the controller binded to the MicroK8s cluster, e.g.
juju switch microk8s
The Juju controller can work with different models; models host applications such as Charmed Kafka K8s. Set up a specific model for Charmed Kafka K8s named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by entering the command juju status
into the command line. You should see the following:
tutorial microk8s microk8s/localhost 3.1.5 unsupported 15:46:55+02:00
Model "admin/tutorial" is empty.
