Kafka K8s
- By Canonical Data Platform
3/beta | 56 | 27 Feb 2024 | |
3/edge | 60 | 03 May 2024 |
How to deploy Charmed Kafka K8s
To deploy a Charmed Kafka K8s cluster on a bare environment, it is necessary to:
- Set up a Juju Controller
- Set up a Juju Model
- Deploy Charmed Kafka K8s and Charmed ZooKeeper K8s
- (Optionally) Create an external admin user
In the next subsections we will cover these steps separately by referring to relevant Juju documentation and providing details on the Charmed Kafka K8s specifics. If you already have a Juju controller and/or a Juju model, you can skip the associated steps.
Juju Controller setup
Before deploying Kafka, make sure you have a Juju controller accessible from your local environment using the Juju client snap.
The properties of your current controller can be listed using juju show-controller
Make sure that the controller’s backend cloud is K8s.
The cloud information can be retrieved with the following command
juju show-controller | yq '.[].details.cloud'
IMPORTANT If the cloud is not
k8s
, please refer to the Charmed Kafka documentation instead.
You can find more information on how to bootstrap and configure a controller for different
clouds here.
Make sure you bootstrap a k8s
Juju controller.
Juju Model setup
You can create a new Juju model using
juju add-model <model>
Alternatively, you can use a pre-existing Juju model and switch to it by running the following command:
juju switch <model-name>
Make sure that the model is not a k8s
type. The type of the model
can be obtained by
juju show-model | yq '.[].type'
IMPORTANT If the model is not
k8s
The Kafka and ZooKeeper charms can both be deployed as follows:
$ juju deploy zookeeper-k8s --channel 3/edge -n <zookeeper-units>
$ juju deploy kafka-k8s --channel 3/edge -n <kafka-units>
After this, it is necessary to connect them:
$ juju relate kafka-k8s zookeeper-k8s
We recommend values for
<kafka-units>
of at least 3 and for<zookeeper-units>
of 5, to ensure reasonable high-availability margins.
Once all the units show as active|idle
in the juju status
output, the deployment
should be ready to be used.
(Optional) Create an external admin users
Charmed Kafka aims to follow the secure by default paradigm. As a consequence, after being deployed the Kafka cluster won’t expose any external listener. In fact, ports are only opened when client applications are related, also depending on the protocols to be used. Please refer to this table for more information about the available listeners and protocols.
It is however generally useful for most of the use-cases to create a first admin user to be used to manage the Kafka cluster (either internally or externally).
To create an admin user, deploy the Data Integrator Charm with
extra-user-roles
set to admin
juju deploy data-integrator --channel stable --config topic-name=test-topic --config extra-user-roles=admin
and relate to the Kafka charm
juju relate data-integrator kafka-k8s
To retrieve authentication information such as the username, password, etc. use
