Kafka K8s
- By Canonical Data Platform
3/beta | 56 | 27 Feb 2024 | |
3/edge | 60 | 03 May 2024 |
This is part of the Charmed Kafka K8s Tutorial. Please refer to this page for more information and the overview of the content.
Manage Passwords
Passwords help to secure our cluster and are essential for security. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password both for the admin user and external Kafka users managed by the data-integrator.
Admin user
The admin user password management is handled directing by the charm, by using Juju actions.
Retrieve the password
As previously mentioned, the admin password can be retrieved by running the get-admin-credentials
action on the Charmed Kafka application:
juju run kafka-k8s/leader get-admin-credentials
Running operation 12 with 1 task
- task 13 on unit-kafka-k8s-2
Waiting for task 13...
client-properties: |-
sasl.mechanism=SCRAM-SHA-512
sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required username="admin" password="0FIQ5QxSaNfl1bXHtV5dyttb21Nbzmpp";
security.protocol=SASL_PLAINTEXT
bootstrap.servers=kafka-k8s-2.kafka-k8s-endpoints:9092,kafka-k8s-0.kafka-k8s-endpoints:9092,kafka-k8s-1.kafka-k8s-endpoints:9092
password: 0FIQ5QxSaNfl1bXHtV5dyttb21Nbzmpp
username: admin
The admin password is under the result: password
Rotate the admin password
You can change the admin password to a new random password by entering:
juju run kafka-k8s/leader set-password username=admin
Running operation 14 with 1 task
- task 15 on unit-kafka-k8s-2
Waiting for task 15...
admin-password: Fz6wPkfGtgjnQ3PCJuZnzJESudZkAvrV
The admin password is under the result: admin-password
. It should be different from your previous password.
Note when you change the admin password you will also need to update the admin password the in Kafka connection parameters; as the old password will no longer be valid.
Set the admin password
You can change the admin password to a specific password by entering:
juju run kafka-k8s/leader set-password username=admin password=my-new-password
Running operation 18 with 1 task
- task 19 on unit-kafka-k8s-2
Waiting for task 19...
admin-password: my-new-password
The admin password under the result: admin-password
should match the password we provided as the action argument.
Note that when you change the admin password you will also need to update the admin password in the Kafka connection parameters, as the old password will no longer be valid.
External Kafka users
Unlike Admin management, the password management for external Kafka users is instead managed using relations. Let’s see this into play with the Data Integrator charm, that we have deployed in the previous part of the tutorial.
Similarly to the Kafka application, also the data-integrator
exposes an action to retrieve the credentials, e.g.
Running operation 22 with 1 task
- task 23 on unit-data-integrator-0
Waiting for task 23...
kafka:
endpoints: kafka-k8s-2.kafka-k8s-endpoints:9092,kafka-k8s-1.kafka-k8s-endpoints:9092,kafka-k8s-0.kafka-k8s-endpoints:9092
password: S4IeRaYaiiq0tsM7m2UZuP2mSI573IGV
tls: disabled
topic: test-topic
username: relation-6
zookeeper-uris: zookeeper-k8s-0.zookeeper-k8s-endpoints:2181,zookeeper-k8s-1.zookeeper-k8s-endpoints:2181,zookeeper-k8s-2.zookeeper-k8s-endpoints:2181/kafka-k8s
ok: "True"
As before, the admin password is under the result: password
Rotate the password
The easiest way to rotate user credentials using the data-integrator
is by removing and then re-relating the data-integrator
with the kafka-k8s
charm
juju remove-relation kafka-k8s data-integrator
# wait for the relation to be torn down
juju relate kafka-k8s data-integrator
The successful credential rotation can be confirmed by retrieving the new password with the action get-credentials
Running the command should now output a different password:
Running operation 24 with 1 task
- task 25 on unit-data-integrator-0
Waiting for task 25...
kafka:
endpoints: kafka-k8s-0.kafka-k8s-endpoints:9092,kafka-k8s-1.kafka-k8s-endpoints:9092,kafka-k8s-2.kafka-k8s-endpoints:9092
password: ToVfqYQ7tWmNmjy2tJTqulZHmJxJqQ22
tls: disabled
topic: test-topic
username: relation-11
ok: "True"
In order to rotate external password with no or limited downtime, please refer to the how-to guide on app management.
Remove the user
To remove the user, remove the relation. Removing the relation automatically removes the user that was created when the relation was created. Enter the following to remove the relation:
The output of the juju model should be something like this:
tutorial microk8s microk8s/localhost 3.1.5 unsupported 17:22:21+02:00
data-integrator blocked 1 data-integrator stable 11 10.152.183.231 no Please relate the data-integrator with the desired product
kafka-k8s active 3 kafka-k8s 3/beta 46 10.152.183.237 no
zookeeper-k8s active 3 zookeeper-k8s 3/beta 37 10.152.183.134 no
data-integrator/0* blocked idle 10.1.36.42 Please relate the data-integrator with the desired product
kafka-k8s/0 active idle 10.1.36.78
kafka-k8s/1 active idle 10.1.36.80
kafka-k8s/2* active idle 10.1.36.79
zookeeper-k8s/0 active idle 10.1.36.84
zookeeper-k8s/1* active idle 10.1.36.86
zookeeper-k8s/2 active idle 10.1.36.85
Note The operations above would also apply to charmed applications that implement the
kafka_client
relation, for which password rotation and user deletion can be achieved in the same consistent way.
What’s next?
In the next part, we will now see how easy it is to enable encryption across the board, to make sure no one is eavesdropping, sniffing or snooping your traffic by enabling TLS.
