Kafka K8s
- By Canonical Data Platform
3/beta | 56 | 27 Feb 2024 | |
3/edge | 60 | 03 May 2024 |
This is part of the Charmed Kafka K8s Tutorial. Please refer to this page for more information and the overview of the content.
Integrate with client applications
As mentioned in the previous section of the Tutorial, the recommended way to create and manage users is by means of another charm: the Data Integrator Charm. This will allow us to encode users directly in the Juju model, and - as shown in the following - to rotate user credentials rotations with and without application downtime using Relations.
Relations, or what Juju documentation describes also as Integration, allow two charms to exchange information and interact with one another. Creating a relation between Kafka and the Data Integrator will allow us to automatically create a username, password, and topic for the desired user/application, and this is indeed the easiest way to create and manage users for Kafka in Charmed Kafka.
The Data Integrator Charm is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms (e.g. MongoDB, MySQL, PostgreSQL, Kafka, OpenSearch, etc) with a consistent, opinionated and robust user experience. In order to deploy the Data Integrator Charm we can use the command juju deploy
we have learned above:
juju deploy data-integrator --channel stable --config topic-name=test-topic --config extra-user-roles=admin
Relate to Kafka
Now that the Database Integrator Charm has been set up, we can relate it to Kafka. This will automatically create a username, password, and database for the Database Integrator Charm. Relate the two applications with:
juju relate data-integrator kafka-k8s
Wait for juju status --watch 1s
to show:
tutorial microk8s microk8s/localhost 3.1.5 unsupported 18:18:16+02:00
data-integrator active 1 data-integrator stable 13 10.152.183.188 no
kafka-k8s active 3 kafka-k8s 3/edge 39 10.152.183.237 no
zookeeper-k8s active 3 zookeeper-k8s 3/edge 33 10.152.183.134 no
data-integrator/0* active idle 10.1.36.87
kafka-k8s/0 active idle 10.1.36.78
kafka-k8s/1 active idle 10.1.36.80
kafka-k8s/2* active idle 10.1.36.79
zookeeper-k8s/0 active idle 10.1.36.84
zookeeper-k8s/1* active idle 10.1.36.86
zookeeper-k8s/2 active idle 10.1.36.85
To retrieve information such as the username, password, and topic. Enter:
This should output something like:
Running operation 5 with 1 task
- task 6 on unit-data-integrator-0
Waiting for task 6...
kafka:
endpoints: kafka-k8s-2.kafka-k8s-endpoints:9092,kafka-k8s-0.kafka-k8s-endpoints:9092,kafka-k8s-1.kafka-k8s-endpoints:9092
password: S4IeRaYaiiq0tsM7m2UZuP2mSI573IGV
tls: disabled
topic: test-topic
username: relation-6
zookeeper-uris: zookeeper-k8s-0.zookeeper-k8s-endpoints:2181,zookeeper-k8s-1.zookeeper-k8s-endpoints:2181,zookeeper-k8s-2.zookeeper-k8s-endpoints:2181/kafka-k8s
ok: "True"
Save the value listed under endpoints
, username
and password
. (Note: your hostnames, usernames, and passwords will likely be different.)
Produce/Consume messages
We will now use the username and password to produce some messages to Kafka. To do so, we will first deploy the Kafka Test App (available here): a test charm that also bundles some python scripts to push data to Kafka, e.g.
juju deploy kafka-test-app -n1 --channel edge
Once the charm is up and running, you can log into the container
juju ssh kafka-test-app/0 /bin/bash
and make sure that the Python virtual environment libraries are visible:
export PYTHONPATH="/var/lib/juju/agents/unit-kafka-test-app-0/charm/venv:/var/lib/juju/agents/unit-kafka-test-app-0/charm/lib"
Once this is setup, you should be able to use the client.py
script that exposes some functionality to produce and consume messages.
You can explore the usage of the script
python3 -m charms.kafka.v0.client --help
usage: client.py [-h] [-t TOPIC] [-u USERNAME] [-p PASSWORD] [-c CONSUMER_GROUP_PREFIX] [-s SERVERS] [-x SECURITY_PROTOCOL] [-n NUM_MESSAGES] [-r REPLICATION_FACTOR] [--num-partitions NUM_PARTITIONS]
[--producer] [--consumer] [--cafile-path CAFILE_PATH] [--certfile-path CERTFILE_PATH] [--keyfile-path KEYFILE_PATH] [--mongo-uri MONGO_URI] [--origin ORIGIN]
Handler for running a Kafka client
options:
-h, --help show this help message and exit
-t TOPIC, --topic TOPIC
Kafka topic provided by Kafka Charm
-u USERNAME, --username USERNAME
Kafka username provided by Kafka Charm
-p PASSWORD, --password PASSWORD
Kafka password provided by Kafka Charm
-c CONSUMER_GROUP_PREFIX, --consumer-group-prefix CONSUMER_GROUP_PREFIX
Kafka consumer-group-prefix provided by Kafka Charm
-s SERVERS, --servers SERVERS
comma delimited list of Kafka bootstrap-server strings
-x SECURITY_PROTOCOL, --security-protocol SECURITY_PROTOCOL
security protocol used for authentication
-n NUM_MESSAGES, --num-messages NUM_MESSAGES
number of messages to send from a producer
-r REPLICATION_FACTOR, --replication-factor REPLICATION_FACTOR
replcation.factor for created topics
partitions for created topics
--producer
--consumer
--origin ORIGIN
Using this script, you can therefore start producing messages
python3 -m charms.kafka.v0.client \
-u relation-6 -p S4IeRaYaiiq0tsM7m2UZuP2mSI573IGV \
-t test-topic \
-s "kafka-k8s-2.kafka-k8s-endpoints:9092,kafka-k8s-0.kafka-k8s-endpoints:9092,kafka-k8s-1.kafka-k8s-endpoints:9092" \
-n 10 --producer \
-r 3 --num-partitions 1
and consume them
-t test-topic \
--consumer \
-c "cg"
Charm Client Applications
Actually, the Data Integrator is only a very special client charm, that implements the kafka_client
relation for exchanging data with the Kafka charm and allowing user management via relations.
For example, the steps above for producing and consuming messages to Kafka have also been implemented in the kafka-test-app
charm (that also implement the kafka_client
relation) providing a fully integrated charmed user-experience, where producing/consuming messages can simply be achieved using relations.
Producing messages
To produce messages to Kafka, we need to configure the kafka-test-app to act as producer, publishing messages to a specific topic
juju config kafka-test-app topic_name=test_kafka_app_topic role=producer num_messages=20
In order to start to produce messages to Kafka, we JUST simply relate the Kafka Test App with Kafka
juju relate kafka-test-app kafka-k8s
Note This will both take care of creating a dedicated user (as much as done for the data-integrator) as well as start a producer process publishing messages to the
topic.
After some time, the juju status
output should show
tutorial microk8s microk8s/localhost 3.1.5 unsupported 18:58:47+02:00
kafka-test-app active 1 kafka-test-app edge 8 10.152.183.60 no Topic test_kafka_app_topic enabled with process producer
kafka-test-app/0* active idle 10.1.36.88 Topic test_kafka_app_topic enabled with process producer
indicating that the process has started. To make sure that this is indeed the case, you can check the logs of the process:
juju exec --application kafka-test-app "tail /tmp/*.log"
To stop the process (although it is very likely that the process has already stopped given the low number of messages that were provided) and remove the user, you can just remove the relation
juju remove-relation kafka-test-app kafka-k8s
Consuming messages
Note that the kafka-test-app
charm can also similarly be used to consume messages by changing its configuration to
juju config kafka-test-app topic_name=test_kafka_app_topic role=consumer consumer_group_prefix=cg
After configuring the Kafka Test App, just relate it again with the Kafka charm. This will again create a new user and start the consumer process.
What’s next?
In the next section, we will learn how to rotate and manage the passwords for the Kafka users, both the admin one and the ones managed by the data-integrator.
