26.04 24.04 22.04 20.04 18.04
latest/stable 952 01 Oct 2026
Ubuntu 26.04 Ubuntu 24.04 Ubuntu 22.04 Ubuntu 20.04 Ubuntu 18.04
latest/stable 951 01 Oct 2026
latest/stable 950 01 Oct 2026
latest/stable 949 01 Oct 2026
latest/stable 948 01 Oct 2026
latest/stable 947 01 Oct 2026
latest/stable 946 01 Oct 2026
latest/stable 945 01 Oct 2026
latest/stable 944 01 Oct 2026
latest/stable 943 01 Oct 2026
latest/stable 942 01 Oct 2026
latest/stable 941 01 Oct 2026
latest/stable 940 01 Oct 2026
latest/stable 939 01 Oct 2026
latest/stable 938 01 Oct 2026
latest/stable 937 01 Oct 2026
latest/stable 15 17 Jan 2025
latest/candidate 952 29 Sep 2026
latest/candidate 951 29 Sep 2026
latest/candidate 950 29 Sep 2026
latest/candidate 949 29 Sep 2026
latest/candidate 948 29 Sep 2026
latest/candidate 947 29 Sep 2026
latest/candidate 946 29 Sep 2026
latest/candidate 945 29 Sep 2026
latest/candidate 944 29 Sep 2026
latest/candidate 943 29 Sep 2026
latest/candidate 942 29 Sep 2026
latest/candidate 941 29 Sep 2026
latest/candidate 940 29 Sep 2026
latest/candidate 939 29 Sep 2026
latest/candidate 938 29 Sep 2026
latest/candidate 937 29 Sep 2026
latest/candidate 15 02 Jan 2025
latest/edge 952 16 Sep 2026
latest/edge 951 16 Sep 2026
latest/edge 950 16 Sep 2026
latest/edge 949 16 Sep 2026
latest/edge 948 16 Sep 2026
latest/edge 947 16 Sep 2026
latest/edge 946 16 Sep 2026
latest/edge 945 16 Sep 2026
latest/edge 944 16 Sep 2026
latest/edge 943 16 Sep 2026
latest/edge 942 16 Sep 2026
latest/edge 941 16 Sep 2026
latest/edge 940 16 Sep 2026
latest/edge 939 16 Sep 2026
latest/edge 938 16 Sep 2026
latest/edge 937 16 Sep 2026
latest/edge 15 03 Nov 2023
juju deploy hardware-observer
Metrics
The details of the metrics exposed by Hardware Observer for IPMI are as follows:
Metric Name Description Labels
ipmi_generic_sensor_value Sensor values from ipmi sensors that aren’t covered in any of the other sensor metrics. id, name, state, unit, event, type
ipmi_fan_speed_rpm Fan speed measure, in rpm. id, name, state, unit, event
ipmi_fan_speed_ratio Fan speed measure, as a percentage of maximum speed. id, name, state, unit, event
ipmi_temperature_celsius Temperature in celsius as recorded by ipmi sensors. id, name, state, unit, event
ipmi_voltage_volts Voltage measure from voltage sensors id, name, state, unit, event
ipmi_current_amperes Current measure from current sensors, in Amperes id, name, state, unit, event
ipmi_power_watts Power measure from power sensors, in watts. id, name, state, unit, event
ipmimonitoring_command_success Indicates if the ipmimonitoring command succeeded or not(1.0 = successful, 0.0 = unsuccessful)
ipmi_sel_state_nominal The ID for IPMI SEL nominal event id, date, time, name, type, event
ipmi_sel_state_warning The ID for IPMI SEL warning event id, date, time, name, type, event
ipmi_sel_state_critical The ID for IPMI SEL critical event id, date, time, name, type, event
ipmi_sel_command_success Indicates if the ipmi sel command succeeded or not(1.0 = successful, 0.0 = unsuccessful)
ipmi_dcmi_power_cosumption_watts Current power consumption in watts, as given by ipmi-dcmi
ipmi_dcmi_command_success Indicates if the ipmi dcmi command is successful or not(1.0 = successful, 0.0 = unsuccessful)
Alerts
The details of the alerts that are provided by Hardware Observer for IPMI are as follows:
Alert Rule Name Description Severity
IPMIDCMICommandFailed Failed to run ipmi_dcmi. critical
IPMIDCMIPowerConsumptionOutstanding IPMI DCMI power consumption is high. warning
IPMISELCommandFailed Failed to run ipmi-sel. critical
IPMISELStateWarning IPMI system event log in warning state. warning
IPMISELStateCritical IPMI system event log in critical state. critical
IPMIMonitoringCommandFailed Failed to run ipmimonitoring. critical
IPMITemperatureStateNotOk Temperature in warning or critical state warning / critical
IPMIPowerStateNotOk Power in warning or critical state warning / critical
IPMIVoltageStateNotOk Voltage in warning or critical state warning / critical
IPMICurrentStateNotOk Current in warning or critical state warning / critical
IPMIFanSpeedStateNotOk Fan speed in warning or critical state warning / critical
IPMISensorStateNotOk IPMI sensor value in warning or critical state warning / critical
IPMISELDStateWarning IPMISELD service is not active warning
IPMISELDStateCritical IPMI system event log in critical state critical
Help improve this document in the forum (guidelines). Last updated 1 year, 5 months ago.
