Grafana Agent
| 0.40/stable | 233 | 07 Jul 2026 | |
| 0.40/stable | 232 | 07 Jul 2026 | |
| 0.40/candidate | 243 | 07 Aug 2026 | |
| 0.40/candidate | 242 | 07 Aug 2026 | |
| 0.40/beta | 243 | 07 Aug 2026 | |
| 0.40/beta | 242 | 07 Aug 2026 | |
| 0.40/edge | 243 | 06 Aug 2026 | |
| 0.40/edge | 242 | 06 Aug 2026 | |
| dev/edge | 253 | 29 Aug 2026 | |
| dev/edge | 252 | 29 Aug 2026 | |
| 2/stable | 211 | 16 Mar 2026 | |
| 2/stable | 210 | 16 Mar 2026 | |
| 2/candidate | 221 | 18 Jun 2026 | |
| 2/candidate | 220 | 18 Jun 2026 | |
| 2/beta | 221 | 18 Jun 2026 | |
| 2/beta | 220 | 18 Jun 2026 | |
| 2/edge | 221 | 17 Jun 2026 | |
| 2/edge | 220 | 17 Jun 2026 | |
| 1/stable | 163 | 18 Sep 2025 | |
| 1/stable | 164 | 18 Sep 2025 | |
| 1/candidate | 168 | 07 Apr 2026 | |
| 1/candidate | 167 | 07 Apr 2026 | |
| 1/beta | 168 | 31 Mar 2026 | |
| 1/beta | 167 | 31 Mar 2026 | |
| 1/edge | 168 | 25 Sep 2025 | |
| 1/edge | 167 | 25 Sep 2025 |
juju deploy grafana-agent-k8s --channel 2/edge
Solution matrix
| K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload | |
| Logs | LokiPushApiConsumer (for workloads that can communicate directly with Loki, LogProxyConsumer (installs promtail in the workload; not suitable for air-gapped), LogForwarder (pebble-native, Juju>=3.4.1) | cos_agent (subordinate, pulls logs from /var/log or from other snaps with a matching slot) |
| Metrics | prometheus_scrape (in-model), prometheus_remote_write (CMR) - with grafana-agent | cos_agent | cos-proxy | scrape-target, grafana-agent snap |
| Traces | tracing (instrumented workloads), charm_tracing (for the charm itself) | tracing (CMR), cos_agent | N/A | grafana-agent charm |
| Dashboards | grafana_dashboard, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
| Alert rules | via metrics and logs relations, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
