Grafana Agent
- Canonical Observability
latest/stable | 75 | 04 Jun 2024 | |
latest/stable | 45 | 12 Dec 2023 | |
latest/candidate | 80 | 01 Aug 2024 | |
latest/candidate | 75 | 04 Jun 2024 | |
latest/candidate | 45 | 22 Nov 2023 | |
latest/beta | 75 | 22 May 2024 | |
latest/beta | 45 | 22 Nov 2023 | |
latest/edge | 97 | 14 Nov 2024 | |
latest/edge | 75 | 03 May 2024 | |
latest/edge | 45 | 15 Sep 2023 | |
1.0/stable | 51 | 12 Dec 2023 | |
1.0/stable | 45 | 12 Dec 2023 | |
1.0/candidate | 51 | 22 Nov 2023 | |
1.0/candidate | 45 | 22 Nov 2023 | |
1.0/beta | 51 | 22 Nov 2023 | |
1.0/beta | 45 | 22 Nov 2023 | |
1.0/edge | 51 | 22 Nov 2023 | |
1.0/edge | 45 | 22 Nov 2023 |
juju deploy grafana-agent-k8s --channel 1.0/edge
Solution matrix
K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload | |
Logs | LokiPushApiConsumer (for workloads that can communicate directly with Loki, LogProxyConsumer (installs promtail in the workload; not suitable for air-gapped), LogForwarder (pebble-native, Juju>=3.4.1) | cos_agent (subordinate, pulls logs from /var/log or from other snaps with a matching slot) |
Metrics | prometheus_scrape (in-model), prometheus_remote_write (CMR) - with grafana-agent | cos_agent | cos-proxy | scrape-target, grafana-agent snap |
Traces | tracing (instrumented workloads), charm_tracing (for the charm itself) | tracing (CMR), cos_agent | N/A | grafana-agent charm |
Dashboards | grafana_dashboard, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
Alert rules | via metrics and logs relations, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
