Canonical Observability Stack Proxy
24.04
22.04
20.04
| 3.0/stable | 169 | 07 Jul 2026 | |
| 3.0/stable | 168 | 07 Jul 2026 | |
| 3.0/stable | 170 | 07 Jul 2026 | |
| 3.0/candidate | 169 | 07 Jul 2026 | |
| 3.0/candidate | 168 | 07 Jul 2026 | |
| 3.0/candidate | 170 | 07 Jul 2026 | |
| 3.0/beta | 169 | 07 Jul 2026 | |
| 3.0/beta | 168 | 07 Jul 2026 | |
| 3.0/beta | 170 | 07 Jul 2026 | |
| 3.0/edge | 170 | 07 Jul 2026 | |
| 3.0/edge | 169 | 07 Jul 2026 | |
| 3.0/edge | 168 | 07 Jul 2026 | |
| dev/edge | 174 | 12 Aug 2026 | |
| dev/edge | 173 | 12 Aug 2026 | |
| dev/edge | 172 | 12 Aug 2026 | |
| dev/edge | 171 | 12 Aug 2026 | |
| 2/stable | 167 | 12 Nov 2025 | |
| 2/stable | 166 | 12 Nov 2025 | |
| 2/candidate | 167 | 08 Oct 2025 | |
| 2/candidate | 166 | 08 Oct 2025 | |
| 2/beta | 167 | 31 Mar 2026 | |
| 2/beta | 166 | 31 Mar 2026 | |
| 2/edge | 167 | 26 Sep 2025 | |
| 2/edge | 166 | 26 Sep 2025 | |
| 1/stable | 155 | 08 Jul 2025 | |
| 1/stable | 156 | 08 Jul 2025 | |
| 1/stable | 139 | 26 Jun 2025 | |
| 1/stable | 140 | 26 Jun 2025 | |
| 1/candidate | 155 | 26 Jun 2025 | |
| 1/candidate | 156 | 26 Jun 2025 | |
| 1/candidate | 139 | 10 Jun 2025 | |
| 1/candidate | 140 | 10 Jun 2025 | |
| 1/beta | 155 | 10 Jun 2025 | |
| 1/beta | 156 | 10 Jun 2025 | |
| 1/beta | 139 | 13 May 2025 | |
| 1/beta | 140 | 13 May 2025 | |
| 1/edge | 156 | 05 Jun 2025 | |
| 1/edge | 155 | 05 Jun 2025 | |
| 1/edge | 140 | 13 May 2025 | |
| 1/edge | 139 | 13 May 2025 |
juju deploy cos-proxy --channel 2/edge
Solution matrix
| K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload | |
| Logs | LokiPushApiConsumer (for workloads that can communicate directly with Loki, LogProxyConsumer (installs promtail in the workload; not suitable for air-gapped), LogForwarder (pebble-native, Juju>=3.4.1) | cos_agent (subordinate, pulls logs from /var/log or from other snaps with a matching slot) |
| Metrics | prometheus_scrape (in-model), prometheus_remote_write (CMR) - with grafana-agent | cos_agent | cos-proxy | scrape-target, grafana-agent snap |
| Traces | tracing (instrumented workloads), charm_tracing (for the charm itself) | tracing (CMR), cos_agent | N/A | grafana-agent charm |
| Dashboards | grafana_dashboard, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
| Alert rules | via metrics and logs relations, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
