Alertmanager
- By Canonical Observability
latest/stable | 106 | 10 Apr 2024 | |
latest/candidate | 108 | 24 Apr 2024 | |
latest/beta | 109 | 24 Apr 2024 | |
latest/edge | 112 | 29 Apr 2024 | |
1.0/stable | 96 | 12 Dec 2023 | |
1.0/candidate | 96 | 22 Nov 2023 | |
1.0/beta | 96 | 22 Nov 2023 | |
1.0/edge | 96 | 22 Nov 2023 |
juju deploy alertmanager-k8s --channel 1.0/edge
Solution matrix
K8s charm | Machine charm | Legacy charms - LMA deps | Non-juju workload | |
Logs | LokiPushApiConsumer (for workloads that can communicate directly with Loki) and LogProxyConsumer (installs promtail in the workload) | cos_agent (subordinate, pulls logs from /var/log or from other snaps with a matching slot) |
Metrics | prometheus_scrape (in-model), prometheus_remote_write (CMR) - with grafana-agent | cos_agent | cos-proxy | scrape-target, grafana-agent snap |
Traces | tracing (instrumented workloads), charm_tracing (for the charm itself) | tracing (CMR), cos_agent | N/A | (manually configured) |
Dashboards | grafana_dashboard, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
Alert rules | via metrics and logs relations, cos-configuration | cos_agent, cos-configuration | cos-proxy, cos-configuration | cos-configuration |
