WordPress
- By Canonical IS DevOps
latest/stable | 87 | 07 Mar 2024 | |
latest/edge | 99 | 07 May 2024 |
juju deploy wordpress-k8s --channel edge
How to integrate with COS
prometheus-k8s
Deploy and relate prometheus-k8s charm with wordpress-k8s
charm through the metrics-endpoint
relation via prometheus_scrape
interface. Prometheus should
start scraping the metrics exposed at :9117/metrics
endpoint.
juju deploy prometheus-k8s
juju relate wordpress-k8s prometheus-k8s
loki-k8s
Deploy and relate loki-k8s charm with wordpress-k8s charm through
the logging
relation via loki_push_api
interface. Promtail worker should spawn and start pushing
Apache access logs and error logs to loki.
juju deploy loki-k8s
juju relate wordpress-k8s loki-k8s
grafana-k8s
In order for the Grafana dashboard to function properly, grafana should be able to connect to
Prometheus and Loki as its datasource. Deploy and relate prometheus-k8s and lok-k8s charm with
grafana-k8s charm through grafana-source
relation.
Note that the relation “grafana-source” has to be explicitly stated since prometheus-k8s and grafana-k8s share multiple interfaces.
juju deploy grafana-k8s
juju relate prometheus-k8s:grafana-source grafana-k8s:grafana-source
juju relate loki-k8s:grafana-source grafana-k8s:grafana-source
Then, wordpress-k8s charm can be related with grafana using the grafana-dashboard
relation with
grafana_dashboard
interface.
juju relate wordpress-k8s grafana-k8s
To access the Grafana dashboard for wordpress-k8s charm, run the following command to obtain credentials for admin access.
juju run-action grafana-k8s/0 get-admin-password --wait
You can now log into the grafana dashboard by visiting http://<grafana-unit-ip>:3000
. Navigate to
http://<grafana-unit-ip>:3000/dashboards
and access the WordPress dashboard named Wordpress Operator
Overview.
