Vault
2.0/stable 590 06 Oct 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 607 Today
Ubuntu 24.04
2.0/edge 606 Today
Ubuntu 24.04
2.0/edge 603 15 Oct 2026
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 591 07 Oct 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
Security in Charmed Vault
  • Built using a bare-bones, distroless Vault ROCK image which is regularly built and scanned for vulnerabilities
  • TLS 1.3 encrypted communication amongst the Vault units, and any communication channels between clients the Vault server
  • Policies that restrict the access of the Charm to only the essential operations
  • Policies that restrict the access of credentials generated by the charm to the minimum set of operations needed.
  • Canonical Observability Stack integration
  • Audit logging
  • Short-lived token TTLs
vault token create -ttl=5m
Handling Unseal Keys
When to use Auto-unseal
  1. Is fully trusted to handle the decryption keys of your Vault
  2. Has minimal downtime
  3. Has processes in place to ensure that new nodes can be unsealed promptly when necessary
Help improve this document in the forum (guidelines). Last updated 1 year, 6 months ago.
