Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 590 06 Oct 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 604 Yesterday
Ubuntu 24.04
2.0/edge 603 Yesterday
Ubuntu 24.04
2.0/edge 602 Yesterday
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 591 07 Oct 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel 1.15/candidate
Use Vault behind an Ingress
It is recommended to run Vault behind an ingress. The charm offers two integrations one that allows accessing Vault behind an ingress through a single endpoint and a second that allows accessing each of the units separately. In this guide we will list the necessary steps to achieve this using the Traefik-K8s operator.
Pre-requisites
  • Vault-K8s deployed on a Juju model
Steps
Deploy Traefik
juju deploy traefik-k8s --channel edge --trust
Deploy Self Signed Certificates Operator
juju deploy self-signed-certificates --channel beta
Integrate Traefik with Self-Signed-Certificates Operator
juju integrate self-signed-certificates:certificates traefik-k8s:certificates
Integrate Vault with Traefik
juju integrate vault-k8s:send-ca-cert traefik-k8s:receive-ca-cert
juju integrate vault-k8s:ingress traefik-k8s:ingress
juju integrate vault:ingress-per-unit traefik-k8s:ingress-per-unit
The ingress integration will allow accessing Vault through a single endpoint while the ingress-per-unit integration will allow accessing each of the units individually.
Get the URLs of Vault and each of the units
Run the show-proxied-endpoints action on Traefik.
juju run traefik-k8s/0 show-proxied-endpoints
# Sample Action Output
  - task 2 on unit-traefik-k8s-0
Waiting for task 2...
proxied-endpoints: '{"vault/0": {"url": "https://10.0.0.5/vault-vault-k8s-0"},
  "vault": {"url": "https://10.0.0.5/vault-vault-k8s"}}'
You should now be able to access Vault using the URL in the action output.
Retrieve the Juju secrets list:
user@ubuntu:~$ juju secrets --format=yaml
ck0i0h3q457c7bgte4kg:
  revision: 1
  owner: vault-k8s
  label: vault-ca-certificate
  created: 2023-09-13T02:36:57Z
  updated: 2023-09-13T02:36:57Z
ck0i0krq457c7bgte4l0:
  revision: 1
  owner: vault-k8s
  label: vault-initialization
  created: 2023-09-13T02:37:10Z
  updated: 2023-09-13T02:37:10Z
cks0s1c24l7c77v23p80:
  revision: 1
  expires: 2024-09-13T02:36:10Z
  owner: self-signed-certificates
  label: ca-certificates
Read the vault-initialization secret content:
user@ubuntu:~$ juju show-secret ck0i0krq457c7bgte4l0 --reveal
  revision: 1
  owner: vault-k8s
  created: 2023-08-28T13:33:54Z
  updated: 2023-08-28T13:33:54Z
  content:
    roottoken: hvs.Z3CuzSQno3XMuUgUcm1CmjQK
    unsealkeys: '["11bd448ccfec24db29ed5c14fdfe3d169589f5c5c6b57870e31d738aec623856"]'
Set the vault token for use in the client:
export VAULT_TOKEN=hvs.Z3CuzSQno3XMuUgUcm1CmjQK
Read the Self Signed Certificates operator’s ca-certificates secret content:
user@ubuntu:~$ juju show-secret cks0s1c24l7c77v23p80 --reveal
  revision: 1
  content:
    ca-certificate: |
      -----BEGIN CERTIFICATE-----
      MIIDPTCCAiWgAwIBAgIUGLlWWWj9My3coKtn/EAgequ4rlswDQYJKoZIhvcNAQEL
      BQAwLDELMAkGA1UEBhMCVVMxHTAbBgNVBAMMFFZhdWx0IHNlbGYgc2lnbmVkIENB
      MB4XDTIzMDkxMzAyMzY1MloXDTI0MDkxMjAyMzY1MlowLDELMAkGA1UEBhMCVVMx
      HTAbBgNVBAMMFFZhdWx0IHNlbGYgc2lnbmVkIENBMIIBIjANBgkqhkiG9w0BAQEF
      AAOCAQ8AMIIBCgKCAQEA3zg2cmScuUV+EFKh4gOE6xxeaur6QEvfb1vFKLjTYRst
      iBbM5/BZE6noYwOIeyir2LgLeoLNr1tCc9EYhDJRNdCYPWUXVDZR4vD7kfZG7CUH
      8yXiQ18Q/7tYnJ63Ic3tE2VLf36Rwj6Wr9b9YrZzeqm2zQDvKUelZzsNh/UOCqzi
      Nd6PEZUQq6d7ucTqbEeOxO3UISTZjyQzx6kPsh3w0AQ4cT2kEtxT6Pg7c3bnbzwd
      TN3MOt0pVyY+2Mb6+Ep6cbB6qrluuOLfXNMBarQersddrJmhGfxq72dxIJ70uE8P
      RiyHH9+HqIoFSk5/e5Cc+VUlKnoNNbocYKh90oVcpQIDAQABo1cwVTAfBgNVHQ4E
      GAQWBBQ1EOm+fKnVxnNF1FztMjlS8LNUPDAhBgNVHSMEGjAYgBYEFDUQ6b58qdXG
      c0XUXO0yOVLws1Q8MA8GA1UdEwEB/wQFMAMBAf8wDQYJKoZIhvcNAQELBQADggEB
      AHKZ3PM1Ipxz5rb2ktOZ5G+AShA6dcGnGIWRW/HrH3BgvBABhBKu++IhBu4Hrp/P
      3Xg6hqZklmr30ZKLO6NgyrTOgTv+/IhauIYOzOyEs68kEnkFHmYuV5GSpPZyE9f9
      XshdCENJSi4JdJuYTboWc/yCsAbmlAPhEjxNA7oHKkgoI/eA3uMK3y01LXk0xcOh
      uCFzIGyvfR323czAfD3/4ZyjE9FCiU/0P10re5mVFUiOnnZIc4zP9/9jTS3BYyXE
      lzhpYn0LdcL8ci8LxCv1OjcgCNeC6kRgzgUhbrUmVHAQmC2+c4tmUq/HQnXA0LWI
      cgSs46l4xpaiLnDeBytVdWo=
      -----END CERTIFICATE-----
    privatekey: |
Copy the CA certificate content into a file and set the VAULT_CAPATH environment variable to reference this file:
export VAULT_CAPATH=/path/to/vault_ca.pem
Identify the vault address by setting the VAULT_ADDR environment variable using the Vault URL which is retrieved through show-proxied-endpoints action. In our example, the vault address is “https://10.0.0.5/vault-vault-k8s”:
export VAULT_ADDR="https://10.0.0.5/vault-vault-k8s"
You can now run vault commands against the vault unit.
vault status
vault operator raft list-peers
Help improve this document in the forum (guidelines). Last updated 1 year, 7 months ago.
