Temporary performance degradation
We are currently experiencing service degradation and working on resolving this. Thank you for your patience and understanding.
Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.19/stable 528 21 Apr 2026
Ubuntu 24.04
1.19/candidate 528 03 Apr 2026
Ubuntu 24.04
1.19/beta 528 03 Apr 2026
Ubuntu 24.04
1.19/edge 544 04 May 2026
Ubuntu 24.04
1.19/edge 543 04 May 2026
Ubuntu 24.04
1.18/stable 507 09 Apr 2026
Ubuntu 24.04
1.18/candidate 507 03 Apr 2026
Ubuntu 24.04
1.18/beta 507 03 Apr 2026
Ubuntu 24.04
1.18/edge 534 09 Apr 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel 1.15/candidate
Security in Charmed Vault
  • Built using a bare-bones, distroless Vault ROCK image which is regularly built and scanned for vulnerabilities
  • TLS 1.3 encrypted communication amongst the Vault units, and any communication channels between clients the Vault server
  • Policies that restrict the access of the Charm to only the essential operations
  • Policies that restrict the access of credentials generated by the charm to the minimum set of operations needed.
  • Canonical Observability Stack integration
  • Audit logging
  • Short-lived token TTLs
vault token create -ttl=5m
Handling Unseal Keys
When to use Auto-unseal
  1. Is fully trusted to handle the decryption keys of your Vault
  2. Has minimal downtime
  3. Has processes in place to ensure that new nodes can be unsealed promptly when necessary
Help improve this document in the forum (guidelines). Last updated 1 year, 10 days ago.
