Charmed PostgreSQL K8s
- Canonical
14/edge | 555 | 04 Apr 2025 | |
14/edge | 554 | 04 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
Charmed PostgreSQL K8s Tutorial > 5. Manage passwords
Manage passwords
When we accessed PostgreSQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time, it is a good practice to change the password frequently.
In this section, we will go through setting and changing the password for the admin user.
- Retrieve the operator password
- Rotate the operator password
- Set a new password
- …for the operator user
- …for another user
The operator’s password can be retrieved by running the get-password
action on the Charmed PostgreSQL K8s application:
juju run postgresql-k8s/leader get-password
Running the command above should output:
unit-postgresql-k8s-0:
UnitId: postgresql-k8s/0
results:
password: SYhCduijXTAfg9mU
status: completed
timing:
completed: 2023-03-20 11:10:33 +0000 UTC
enqueued: 2023-03-20 11:10:32 +0000 UTC
started: 2023-03-20 11:10:33 +0000 UTC
You can change the operator’s password to a new random password by entering:
juju run postgresql-k8s/leader set-password
results:
password: 7CYrRiBrC4du3ToX
status: completed
timing:
completed: 2023-03-20 11:10:47 +0000 UTC
enqueued: 2023-03-20 11:10:46 +0000 UTC
started: 2023-03-20 11:10:47 +0000 UTC
The status: completed
element in the output above indicates that the password has been successfully updated. The new password should be different from the previous password.
Set a new password…
You can set a specific password for any user by running the set-password
juju action on the leader unit.
To set a manual password for the operator/admin user, run the following command:
juju run postgresql-k8s/leader set-password password=my-password
where my-password
is your password of choice.
Example output:
results:
password: my-password
status: completed
timing:
completed: 2023-03-20 11:11:06 +0000 UTC
enqueued: 2023-03-20 11:11:02 +0000 UTC
started: 2023-03-20 11:11:05 +0000 UTC
…for another user
To set a manual password for another user, run the following command:
juju run postgresql-k8s/leader set-password username=my-user password=my-password
Read more about internal operator users here.
Next step: 6. Integrate with other applications
