Charmed PostgreSQL K8s
- Canonical
14/edge | 555 | 04 Apr 2025 | |
14/edge | 554 | 04 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
Charmed PostgreSQL K8s Tutorial > 7. Enable TLS
Enable encryption with TLS
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. This has all been encoded into Charmed PostgreSQL K8s. This means (re-)configuring TLS on Charmed PostgreSQL K8s is readily available and requires minimal effort on your end.
Again, integrations come in handy here as TLS is enabled by relating Charmed PostgreSQL K8s to the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this part of the tutorial, you will learn how to enable security in your PostgreSQL deployment using TLS encryption.
Self-signed certificates are not recommended for a production environment.
Check this guide for an overview of the TLS certificates charms available.
Enable TLS
To enable TLS, you must deploy a charm that provides TLS certificates and integrate it with PostgreSQL.
Deploy TLS charm
Before enabling TLS on Charmed PostgreSQL K8s, we must deploy the self-signed-certificates
charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until the self-signed-certificates
is up and active by using juju status --watch 1s
to monitor the deployment status
tutorial charm-dev microk8s/localhost 3.1.7 unsupported 12:18:05+01:00
postgresql-k8s active 2 postgresql-k8s 14/stable 56 10.152.183.167 no
self-signed-certificates active 1 self-signed-certificates stable 72 10.152.183.138 no
postgresql-k8s/0* active idle 10.1.188.206 Primary
postgresql-k8s/1 active idle 10.1.188.209
self-signed-certificates/0* active idle 10.1.188.212
Integrate with PostgreSQL
To enable TLS on Charmed PostgreSQL K8s, integrate the two applications:
juju integrate postgresql-k8s:certificates self-signed-certificates:certificates
Check the TLS certificate in use
Use openssl
to connect to the PostgreSQL and check the TLS certificate in use:
> openssl s_client -starttls postgres -connect 10.1.188.206:5432 | grep Issuer
depth=1 C = US, CN = Tutorial CA
verify error:num=19:self-signed certificate in certificate chain
Congratulations! PostgreSQL is now using TLS certificate generated by the external application self-signed-certificates
Disable TLS
To disable the external TLS, remove the integration:
juju remove-relation postgresql-k8s:certificates self-signed-certificates:certificates
If you once again check the TLS certificates in use via the OpenSSL client, you will see something similar to the output below:
no peer certificate available
No client certificate CA names sent
The Charmed PostgreSQL K8s application is not using TLS anymore.
Next step: 8. Clean up environment
