postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL K8s Tutorial > 7. Clean up environment
Clean up you environment
In this tutorial we’ve successfully deployed PostgreSQL on MicroK8s, added/removed cluster members, added/removed users to/from the database, and even enabled and disabled TLS.
You may now keep your Charmed PostgreSQL K8s deployment running and write to the database or remove it entirely using the steps in this page.
Stop your virtual machine
If you’d like to keep your environment for later, simply stop your VM with
multipass stop my- vm
Delete your virtual machine
If you’re done with testing and would like to free up resources on your machine, you can remove the VM entirely.
Warning: When you remove VM as shown below, you will lose all the data in PostgreSQL and any other applications inside Multipass VM!
For more information, see the docs for multipass delete.
Delete your VM and its data with
multipass delete --purge my-vm
Next Steps
If you’re looking for what to do next, you can:
Help improve this document in the forum (guidelines). Last updated 11 months ago.
