Charmed PostgreSQL K8s
- Canonical
14/edge | 557 | Today | |
14/edge | 556 | Today | |
16/edge | 552 | 02 Apr 2025 |
Supported plugins/extensions
The following list contains all plugins/extensions supported by Charmed PostgreSQL K8s in alphabetical order. The revision column indicates which charm revision introduced support for the extension.
If you need support for other extensions, feel free to reach out to us on our Matrix channel.
Plugin/extension name | Revision |
address_standardizer |
193+ |
address_standardizer_data_us |
193+ |
bloom |
168+ |
bool_plperl |
193+ |
btree_gin |
168+ |
btree_gist |
168+ |
citext |
100+ |
cube |
168+ |
debversion |
100+ |
dict_int |
168+ |
dict_xsyn |
168+ |
earthdistance |
168+ |
fuzzystrmatch |
168+ |
hll |
193+ |
hstore |
100+ |
hstore |
193+ |
hypopg |
193+ |
icu_ext |
193+ |
intarray |
168+ |
ip4r |
193+ |
isn |
168+ |
jsonb_plperl |
193+ |
lo |
168+ |
ltree |
168+ |
old_snapshot |
168+ |
orafce |
193+ |
pg_freespacemap |
168+ |
pg_similarity |
193+ |
pg_trgm |
100+ |
pg_trgm |
193+ |
pg_visibility |
168+ |
pgrowlocks |
168+ |
pgstattuple |
168+ |
pgvector |
193+ |
plperl |
193+ |
plpython3u |
100+ |
pltcl |
193+ |
postgis |
193+ |
postgis_raster |
193+ |
postgis_tiger_geocoder |
193+ |
postgis_topology |
193+ |
prefix |
193+ |
rdkit |
193+ |
seg |
168+ |
spi |
171+ |
tablefunc |
168+ |
tcn |
168+ |
tds_fdw |
193+ |
tsm_system_rows |
168+ |
tsm_system_time |
168+ |
unaccent |
100+ |
unaccent |
193+ |
uuid-ossp |
168+ |
