postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
How to scale units
Replication in PostgreSQL is the process of creating copies of the stored data. This provides redundancy, which means the application can provide self-healing capabilities in case one replica fails. In this context, each replica is equivalent one juju unit.
This guide will show you how to establish and change the amount of juju units used to replicate your data.
Deploy PostgreSQL with replicas
To deploy PostgreSQL with multiple replicas, specify the number of desired units with the -n option:
juju deploy postgresql-k8s --channel 14/stable -n <number_of_replicas>
Primary vs. leader unit
The PostgreSQL primary server unit may or may not be the same as the juju leader unit.
The juju leader unit is the represented in juju status by an asterisk (*) next to its name.
To retrieve the juju unit that corresponds to the PostgreSQL primary, use the action get-primary on any of the units running postgresql:
juju run postgresql-k8s/leader get-primary
Similarly, the primary replica is displayed as a status message in juju status. However, one should note that this hook gets called on regular time intervals and the primary may be outdated if the status hook has not been called recently.
We highly suggest configuring the update-status hook to run frequently. In addition to reporting the primary, secondaries, and other statuses, the status hook performs self-healing in the case of a network cut.
To change the frequency of the update-status hook, run
juju model-config update-status-hook-interval=<time(s/m/h)>
Scale replicas on an existing application
Both scaling up and scaling down operations are performed using juju scale-application:
juju scale-application postgresql-k8s <desired_num_of_units>
Warning: Scaling down to zero units will destroy your data!
Help improve this document in the forum (guidelines). Last updated 8 months ago.
