Charmed PostgreSQL K8s
- Canonical
14/edge | 555 | 04 Apr 2025 | |
14/edge | 554 | 04 Apr 2025 | |
16/edge | 552 | 02 Apr 2025 |
How to migrate a cluster
This is a guide on how to restore a backup that was made from a different cluster, (i.e. cluster migration via restore).
To perform a basic restore (from a local backup), see How to restore a local backup
Restoring a backup from a previous cluster to a current cluster requires:
- A single unit Charmed PostgreSQL deployed and running
- Access to S3 storage
- Configured settings for S3 storage
- Backups from the previous cluster in your S3 storage
- Passwords from your previous cluster
Manage cluster passwords
When you restore a backup from an old cluster, it will restore the password from the previous cluster to your current cluster. Set the password of your current cluster to the previous cluster’s password:
juju run postgresql-k8s/leader set-password username=operator password=<previous cluster password>
juju run postgresql-k8s/leader set-password username=replication password=<previous cluster password>
juju run postgresql-k8s/leader set-password username=rewind password=<previous cluster password>
List backups
To view the available backups to restore, use the command list-backups
juju run postgresql-k8s/leader list-backups
This shows a list of the available backups (it is up to you to identify which backup-id
corresponds to the previous-cluster):
backups:
|backup-id | backup-type | backup-status
YYYY-MM-DDTHH:MM:SSZ | physical | finished
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore
command and pass the correct backup-id
to the command:
juju run postgresql-k8s/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ
Your restore will then be in progress. Once it is complete, your current cluster will represent the state of the previous cluster.
