postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
How to integrate a database with your charm
Charmed PostgreSQL K8s can be integrated with any charmed application that supports its interfaces. This page provides some guidance and resources for charm developers to develop, integrate, and troubleshoot their charm so that it may connect with PostgreSQL.
  • Check supported interfaces
  • Integrate your charm with PostgreSQL
  • Troubleshooting & testing
  • FAQ
First, we recommend that you check the supported interfaces of the current charm. You have options to use modern (preferred) or legacy interfaces.
Most existing charms currently use the ops-lib-pgsql interface (legacy). For new charms, Canonical recommends using data-platform-libs instead.
Legacy charm details are described here.
For an introduction to the concepts of Juju integrations, see Juju | Integration.
For a detailed tutorial about integrating your charm with the PostgreSQL charm, refer to Juju | Integrate your charm with PostgreSQL.
For some practical examples, take a look at the following:
FAQ
Does the requirer need to set anything in relation data?
It depends on the interface. Check the postgresql_client interface requirements.
Is there a charm library available, or does my charm need to compile the postgresql relation data on its own?
Yes, the library is available: data-platform-libs. The integration is trivial: example.
How do I obtain the database url/uri?
This feature is planned but currently missing.
Meanwhile, use this example or refer to the function below.
def _db_connection_string(self) -> str:
   """Report database connection string using info from relation databag."""
   relation = self.model.get_relation("database")
   if not relation:
       return ""
   data = self._database.fetch_relation_data()[relation.id]
   username = data.get("username")
   password = data.get("password")
   endpoints = data.get("endpoints")
   return f"postgres://{username}:{password}@{endpoints}/ratings"
Contact us if you have any questions, issues, or ideas!
Help improve this document in the forum (guidelines). Last updated 10 months ago.
