postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 557 Today
14/edge 556 Today
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
How to create and list backups
This guide contains recommended steps and useful commands for creating and managing backups to ensure smooth restores.
Create a backup
Once you have a three-node cluster with configurations set for S3 storage, check that Charmed PostgreSQL is active and idle with juju status.
Once Charmed PostgreSQL is active and idle, you can create your first backup with the create-backup command:
juju run postgresql-k8s/leader create-backup
By default, backups created with command above will be full backups: a copy of all your data will be stored in S3. There are 2 other supported types of backups (available in revision 263+):
  • Differential: Only modified files since the last full backup will be stored.
  • Incremental: Only modified files since the last successful backup (of any type) will be stored.
To specify the desired backup type, use the type parameter:
juju run postgresql-k8s/leader create-backup type={full|differential|incremental}
Tip: To avoid unnecessary service downtime, always use non-primary units for the action create-backup. Keep in mind that:
  • TLS enabled: disables the command from running on primary units.
  • TLS not enabled: disables the command from running on non-primary units.
List backups
You can list your available, failed, and in-progress backups by running the list-backups command:
juju run postgresql-k8s/leader list-backups
