postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 557 Today
14/edge 556 Today
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Charm flowcharts
The file charm.py is the entrypoint for the charm. It contains functions for its basic operation, including its major hooks and file management. This file can be found at src/charm.py.
Hook Handler Flowcharts
These flowcharts detail the control flow of the hooks in this program. Unless otherwise stated, a hook deferral is always followed by a return.
Leader Elected Hook
Click to navigate the mermaid diagram on GitHub.
Mermaid Diagram
no
yes
no
yes
yes
no
no
yes
leader-elected Hook
Generate password for charm users?
Create k8s resources\n needed by Patroni
Is current unit \n part of the cluster?
Add current unit \n to the cluster
Remove pending departed \n units from the cluster
Has cluster\n initialised?
return
Are all the units \n part of the cluster?
Turn on/off PostgreSQL \n synchronous_commit configuration
Are all cluster \n members ready?
defer
Add unit to cluster
Patch pod labels of the new cluster member
return
PostgreSQL Pebble Ready Hook
Mermaid Diagram
no
yes
no
yes
no
yes
no
yes
yes
no
no
yes
no
yes
leader-elected Hook
Create data\n directory
Is current unit\n leader or has the \n cluster initialised?
defer
Has successfully \n pushed TLS files?
defer
Have pebble \n services changed?
Have Patroni and \n PostgreSQL started in \n the current unit?
Update and restart \n the PostgreSQL service
defer
Is current\nunit leader?
Has successfully \n patched pod labels of \n the new current unit
Set Blocked\nstatus
return
Is custom k8s service \n redirecting traffic to \n primary pod?
Set Waiting\nstatus
defer
Mark cluster as initialised
Set Active\n Status
return
Help improve this document in the forum (guidelines). Last updated 7 months ago.
