postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Backup flowcharts
This document contains backups management flowchart, including all major hooks. This sources can be found at src/backups.py.
Hook Handler Flowcharts
These flowcharts detail the control flow of the hooks in this program. Unless otherwise stated, a hook deferral is always followed by a return.
On S3 Credentials Changed Hook
Click to navigate the mermaid diagram on GitHub.
Mermaid Diagram
no
yes
no
yes
no
yes
yes
no
no
yes
no
yes
yes
no
yes
no
s3-credentials-changed Hook
Has cluster\n initialised?
defer
return
Are all required\nS3 settings provided?
Update backup settings
Is current\nunit leader?
Is unit in\nblocked state?
Could initialise\npgBackRest Stanza?
Set Blocked\nstatus
Is WAL archiving\nto S3 working?
Is TLS disabled or\nsingle unit cluster
Stop pgBackRest\nTLS server
Is current\nunit a replica\nand TLS server isn't\nrunning on primary?
Start pgBackRest\nTLS server
When certificates are received from TLS certificates operator through the certificates relation (or the relation is removed) the steps starting from Is TLS disabled or single unit cluster are also executed.
On Create Backup Hook
Mermaid Diagram
yes
no
yes
no
yes
no
no
yes
no
yes
yes
no
no
yes
no
yes
no
no
yes
yes
no
yes
create-backup Hook
fail action
Is primary in\na TLS enabled\nmultiple units cluster?
Is replica and\nwith TLS disabled?
Has stanza been initialised?
Is S3 relation\nestablished?
Has missing S3 parameters?
Was it possible\nto upload metadata file\nto test connectivity to S3?
Is current\nunit a replica?
Set Maintenance Status
Block new\nconnections to this\nunit's database
Has backup creation succeeded?
Upload error\nlogs to S3
fail action
Set Active Status
Allow new\nconnections to this\nunit's database
Were backup logs\nuploaded to S3?
backup created
On List Backups Hook
Mermaid Diagram
no
yes
yes
no
no
yes
list-backups Hook
fail action
Does pgBackRest\nreturned the\nbackups list?
Return formatted\nbackup list
On Restore Hook
Mermaid Diagram
no
yes
no
yes
yes
no
no
yes
no
yes
no
yes
no
yes
no
yes
restore Hook
Has user provided\na backup id?
fail action
Is workload\ncontainer accessible?
Is single\nunit cluster?
Is backup id\nvalid?
Has database\nstopped?
Was previous cluster\ninfo removed?
Start database again
Was the data\ndirectory emptied?
no
yes
Configure Patroni to restore the backup
Start the database
restore started
The unit status becomes Active or Blocked after a, respectively, successful or failed restore is detected in the update status hook.
Help improve this document in the forum (guidelines). Last updated 1 year, 10 months ago.
