Charmed MongoDB K8s
- By Canonical Data Platform
latest/stable | 14 | 01 Aug 2022 | |
latest/edge | 20 | 02 Mar 2023 | |
6/beta | 38 | 05 Dec 2023 | |
6/edge | 40 | 14 Dec 2023 | |
5/edge | 39 | 14 Dec 2023 |
juju deploy mongodb-k8s --channel 5/edge
System requirements
- Ubuntu 20.04 (focal) or later.
- At least 8GB of RAM.
- At least 2 CPU cores.
- At least 20GB of available storage. For production deployment: at least 60GB of available storage on each host.
- Access to the internet for downloading the required snaps and charms.
- Juju 3.x
Supported architectures
This charm should be running on architectures that support AVX
To check your architecture please execute
grep avx /proc/cpuinfo
or
grep avx2 /proc/cpuinfo
