Charmed MongoDB K8s
- By Canonical Data Platform
latest/stable | 14 | 01 Aug 2022 | |
latest/edge | 20 | 02 Mar 2023 | |
6/beta | 38 | 05 Dec 2023 | |
6/edge | 40 | 14 Dec 2023 | |
5/edge | 39 | 14 Dec 2023 |
juju deploy mongodb-k8s --channel 5/edge
Configuring S3-storage requires that you have a replica set with at least three-nodes deployed and access to S3 storage. If you don’t have a three node replica set read the Managing Units How-To for K8s charm
Once you have a three-node replica set deployed, you can configure your settings for S3. Configurations are managed with the s3-integrator charm. Deploy and configure the s3-integrator charm:
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key-here> secret-key=<secret-key-here>
juju config s3-integrator \
path="mongodb-vm/demo" \
region="us-west-2" \
bucket="pbm-test-bucket-1"
The s3-integrator charm accepts many configurations - enter whatever configurations are necessary for your s3 storage.
To pass these configurations to Charmed MongoDB, relate the two applications:
juju relate s3-integrator mongodb-k8s
You can also update your configuration options after relating:
endpoint=<endpoint>
