Charmed MongoDB K8s
- By Canonical Data Platform
latest/stable | 14 | 01 Aug 2022 | |
latest/edge | 20 | 02 Mar 2023 | |
6/beta | 38 | 05 Dec 2023 | |
6/edge | 40 | 14 Dec 2023 | |
5/edge | 39 | 14 Dec 2023 |
juju deploy mongodb-k8s --channel 5/edge
Relate your MongoDB deployment
This is part of the Charmed MongoDB K8s 5 Tutorial. Please refer to this page for more information and the overview of the content.
Relations
Relations, or what Juju documentation describes as Integration, are the easiest way to create a user for MongoDB in Charmed MongoDB K8s. Relations automatically create a username, password, and database for the desired user/application. As mentioned earlier in the Access MongoDB section it is a better practice to connect to MongoDB via a specific user rather than the admin user.
Data Integrator Charm
Before relating to a charmed application, we must first deploy our charmed application. In this tutorial we will relate to the Data Integrator Charm.
This is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms products (e.g. MongoDB, MySQL, PostgreSQL, Kafka, etc) with a consistent, opinionated and robust user experience.
In order to deploy the Data Integrator Charm we can use the command juju deploy
we have learned previously:
juju deploy data-integrator --channel edge --config database-name=test-database
The expected output:
Located charm "data-integrator" in charm-hub...
Deploying "data-integrator" from charm-hub charm "data-integrator"...
Relate to MongoDB
Now that the Database Integrator Charm has been set up, we can relate it to MongoDB. This will automatically create a username, password, and database for the Database Integrator Charm. Relate the two applications with:
juju relate data-integrator mongodb-k8s
Wait for juju status --watch 1s
to show:
tutorial overlord microk8s/localhost 3.1.6 unsupported 17:24:23Z
data-integrator active 1 data-integrator edge 11 10.152.183.190 no
mongodb-k8s active 2 mongodb-k8s 5/edge 27 10.152.183.20 no
data-integrator/0* active idle 10.1.42.142
mongodb-k8s/0* active idle 10.1.42.137
mongodb-k8s/1 active idle 10.1.42.140
To retrieve information such as the username, password, and database. Type:
This should output something like:
Running operation 19 with 1 task
- task 20 on unit-data-integrator-0
Waiting for task 20...
mongodb:
database: test-database
endpoints: mongodb-k8s-0.mongodb-k8s-endpoints,mongodb-k8s-1.mongodb-k8s-endpoints
password: iW19U0ClFbSDurxMju98Zsgy4BovY4uf
replset: mongodb-k8s
uris: mongodb://relation-2:iW19U0ClFbSDurxMju98Zsgy4BovY4uf@mongodb-k8s-0.mongodb-k8s-endpoints,mongodb-k8s-1.mongodb-k8s-endpoints/test-database?replicaSet=mongodb-k8s&authSource=admin
username: relation-2
ok: "True"
Save the value listed under uris:
(Note: your hostnames, usernames, and passwords will likely be different.)
Access the related database
Notice that in the previous step when you typed juju run-action data-integrator/leader get-credentials --wait
the command not only outputted the username, password, and database, but also outputted the URI. This means you do not have to generate the URI yourself. To connect to this URI first ssh into mongodb-k8s/0
Then access mongo
with the URI that you copied above:
mongo "<uri copied from juju run-action data-integrator/leader get-credentials --wait>"
Note: be sure you wrap the URI in "
with no trailing whitespace.
You will now be in the mongo shell as the user created for this relation. When you relate two applications Charmed MongoDB K8s automatically sets up a user and database for you.
Enter db.getName()
into the MongoDB shell, this will output:
test-database
This is the name of the database we specified when we first deployed the data-integrator
charm.
To create a collection in the “test-database” and then show the collection enter:
db.createCollection("test-collection")
show collections
Now insert a document into this database:
db.test_collection.insertOne(
First_Name: "Jammy",
Last_Name: "Jellyfish",
You can verify this document was inserted by running:
db.test_collection.find()
Now exit the MongoDB shell by typing:
exit
Now you should be back in the host of the Charmed MongoDB K8s’s unit: mongodb-k8s/0
. To exit this host type:
exit
You should now be in the shell you started where you can interact with Juju and Kubernetes (Microk8s).
Remove the user
To remove the user, remove the relation. Removing the relation automatically removes the user that was created when the relation was created. Enter the following to remove the relation:
juju remove-relation mongodb-k8s data-integrator
Now try again to connect to the same URI you just used in Access the related database:
This will output an error message:
Percona Server for MongoDB shell version v5.0.15-13
connecting to: mongodb://mongodb-k8s-2.mongodb-k8s-endpoints:27017,mongodb-k8s-1.mongodb-k8s-endpoints:27017,mongodb-k8s-0.mongodb-k8s-endpoints:27017/test-database?authSource=admin&compressors=disabled&gssapiServiceName=mongodb&replicaSet=mongodb-k8s
Error: can't connect to new replica set primary [mongodb-k8s-0.mongodb-k8s-endpoints:27017], err: AuthenticationFailed: Authentication failed. :
connect@src/mongo/shell/mongo.js:372:17
@(connect):2:6
exception: connect failed
exiting with code 1
As this user no longer exists. This is expected as juju remove-relation mongodb-k8s data-integrator
also removes the user.
Now exit the juju:
exit
If you wanted to recreate this user all you would need to do is relate the two applications again:
juju relate mongodb-k8s data-integrator
Re-relating generates a new password for this user, and therefore a new URI you can see the new URI with:
Save the result listed with uris:
You can connect to the database with this new URI:
From there if you enter db.test_collection.find()
you will see all of your original documents are still present in the database.From there if you enter db.test_collection.find()
exit
Now you should be back in the host of the Charmed MongoDB K8Ss’s unit: mongodb-k8s/0
exit
Next Steps
Charmed MongoDB 5 K8s Tutorial - Enable security
