Charmed Operator for MongoDB
- Canonical
6/stable | 61 | 15 Nov 2024 | |
6/candidate | 61 | 15 Nov 2024 | |
6/beta | 61 | 15 Nov 2024 | |
6/edge | 63 | 12 Mar 2025 | |
5/edge | 39 | 14 Dec 2023 |
juju deploy mongodb-k8s --channel 5/edge
How to manage passwords
Internal operator user
The operator user is used internally by the Charmed MongoDB Operator, the set-password
action can be used to rotate its password.
- To set a specific password for the operator user
juju run mongodb-k8s/leader set-password password=<password>
where is the password you want to set
- To randomly generate a password for the operator user
Rotate application passwords
To rotate the passwords of users created for related applications, the relation should be removed and related again. That process will generate a new user and password for the application.
juju remove-relation <application> mongodb-k8s
juju add-relation <application> mongodb-k8s
where is the name of your application
