mongodb-k8s
Charmed Operator for MongoDB
6/stable 61 15 Nov 2024
6/candidate 61 15 Nov 2024
6/beta 61 15 Nov 2024
6/edge 61 15 Nov 2024
5/edge 39 14 Dec 2023
juju deploy mongodb-k8s --channel 5/edge
How to create a backup
This is a guide on how to create and list backups of a Charmed MongoDB replica set or sharded cluster using Amazon S3 storage.
Determine the application to run backup actions on
The application to pass to juju when running backup and restore actions depends on whether your deployment is a replica set or sharded cluster:
When running Charmed MongoDB K8s as a replica-set, this will be the name of your MongoDB K8s application.
When running Charmed MongoDB K8s as a sharded cluster, this will be the name of your MongoDB K8s application running with the “config-server” role - never the shard applications.
Create a backup
Before creating a backup, check that your Charmed MongoDB K8s deployment is active and idle with juju status.
To create a backup, use the create-backup command on the leader unit:
juju run <replica-set name | config-server name>/leader create-backup
List all backups
To list all available, failed, and in-progress backups, use the list-backup command on the leader unit:
juju run <replica-set name | config-server name>/leader list-backups
Help improve this document in the forum (guidelines). Last updated 3 months ago.
