Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 56 27 Feb 2024
3/edge 74 Yesterday
This is part of the Charmed Kafka Tutorial. Please refer to this page for more information and the overview of the content.
Setup the environment
Multipass is a quick and easy way to launch virtual machines running Ubuntu. It uses “cloud-init” standard to install and configure all the necessary parts automatically.
Let’s install Multipass from Snap and launch a new VM using “charm-dev” cloud-init config:
sudo snap install multipass && \
multipass launch --cpus 4 --memory 8G --disk 50G --name my-vm charm-dev
Note: See all multipass launch parameters in the launch command documentation.
Multipass list of commands is short and self-explanatory, e.g. show all running VMs:
multipass list
As soon as new VM started, enter inside using:
multipass shell my-vm
Note: if at any point you’d like to leave Multipass VM, use Ctrl+D or type exit.
All the parts have been pre-installed inside VM already, like MicroK8s, LXD and Juju (the files /var/log/cloud-init.log and /var/log/cloud-init-output.log contain all low-level installation details). Also, the image already comes with two Juju controllers already setup, one for LXD and one for MicroK8s
$ juju list-controllers
Controller  Model     User   Access     Cloud/Region         Models  Nodes    HA  Version
lxd*        tutorial  admin  superuser  localhost/localhost       2      1  none  3.1.5
microk8s    -         admin  superuser  microk8s/localhost        1      1     -  3.1.5
Make sure that you use the controller bound to the MicroK8s cluster, e.g.
juju switch microk8s
The Juju controller can work with different models; models host applications such as Charmed Kafka K8s. Set up a specific model for Charmed Kafka K8s named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by entering the command juju status into the command line. You should see the following:
tutorial  microk8s    microk8s/localhost  3.1.5    unsupported  15:46:55+02:00
Model "admin/tutorial" is empty.
Help improve this document in the forum (guidelines). Last updated 3 months ago.
