Apache Kafka - K8s
latest/stable 5 09 Mar 2022
Ubuntu 20.04
latest/edge 27 25 Apr 2023
Ubuntu 22.04 Ubuntu 20.04
latest/edge 13 21 Oct 2022
3/stable 56 27 Feb 2024
3/candidate 56 27 Feb 2024
3/beta 56 27 Feb 2024
3/edge 74 Yesterday
How to deploy on EKS
Amazon Elastic Kubernetes Service (EKS) is a popular, fully automated Kubernetes service. To access the EKS Web interface, go to console.aws.amazon.com/eks/home.
Install EKS and Juju tooling
Install Juju and the kubectl CLI tools via snap:
sudo snap install juju
sudo snap install kubectl --classic
Follow the installation guides for:
  • eksctl - the Amazon EKS CLI
  • AWS CLI - the Amazon Web Services CLI
To check they are all correctly installed, you can run the commands demonstrated below with sample outputs:
> juju version
3.1.7-ubuntu-amd64
> kubectl version --client
Client Version: v1.28.2
Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3
> eksctl info
eksctl version: 0.159.0
kubectl version: v1.28.2
> aws --version
aws-cli/2.13.25 Python/3.11.5 Linux/6.2.0-33-generic exe/x86_64.ubuntu.23 prompt/off
Authenticate
Create an IAM account (or use legacy access keys) and login to AWS:
> aws configure
AWS Access Key ID [None]: SECRET_ACCESS_KEY_ID
AWS Secret Access Key [None]: SECRET_ACCESS_KEY_VALUE
Default region name [None]: eu-west-3
Default output format [None]:
> aws sts get-caller-identity
    "UserId": "1234567890",
    "Account": "1234567890",
    "Arn": "arn:aws:iam::1234567890:root"
Create a new EKS cluster
Export the deployment name for further use:
export JUJU_NAME=eks-$USER-$RANDOM
This following examples in this guide will use the location eu-west-3 and K8s v.1.27 - feel free to change this for your own deployment.
Sample cluster.yaml:
~$ cat <<-EOF > cluster.yaml
apiVersion: eksctl.io/v1alpha5
kind: ClusterConfig
metadata:
    region: eu-west-3
    version: "1.27"
iam:
  withOIDC: true
addons:
- name: aws-ebs-csi-driver
  wellKnownPolicies:
    ebsCSIController: true
nodeGroups:
    - name: ng-1
      minSize: 3
      maxSize: 5
      iam:
        attachPolicyARNs:
        - arn:aws:iam::aws:policy/AmazonEKSWorkerNodePolicy
        - arn:aws:iam::aws:policy/AmazonEKS_CNI_Policy
        - arn:aws:iam::aws:policy/AmazonEC2ContainerRegistryReadOnly
        - arn:aws:iam::aws:policy/AmazonSSMManagedInstanceCore
        - arn:aws:iam::aws:policy/AmazonS3FullAccess
      instancesDistribution:
        maxPrice: 0.15
        instanceTypes: ["m5.xlarge", "m5.2xlarge"] # At least two instance types should be specified
        onDemandBaseCapacity: 0
        onDemandPercentageAboveBaseCapacity: 50
        spotInstancePools: 2
EOF
Bootstrap EKS cluster with the following command:
eksctl create cluster -f cluster.yaml
Sample output:
2023-10-12 11:13:58 [ℹ]  using region eu-west-3
2023-10-12 11:13:59 [ℹ]  using Kubernetes version 1.27
2023-10-12 11:40:00 [✔]  EKS cluster "eks-taurus-27506" in "eu-west-3" region is ready
Bootstrap Juju on EKS
Add Juju K8s clouds:
juju add-k8s $JUJU_NAME
Bootstrap Juju controller:
juju bootstrap $JUJU_NAME
Deploy Charms
Create a new Juju model, if needed:
juju add-model <MODEL_NAME>
(Optional) Increase the debug level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Then, Charmed Kafka can be deployed as usual:
juju deploy zookeeper-k8s -n3 --channel 3/stable
juju deploy kafka-k8s -n3 --channel 3/stable
juju integrate kafka-k8s zookeeper-k8s
We also recommend to deploy a Data Integrator for creating an admin user to manage the content of the Kafka cluster:
juju deploy data-integrator admin --channel edge \
  --config extra-user-roles=admin \
  --config topic-name=admin-topic
And integrate it with the Kafka application:
juju integrate kafka-k8s admin
For more information on Data Integrator and how to use it, please refer to the how-to manage applications user guide.
Display deployment information
Display information about the current deployments with the following commands:
~$ kubectl cluster-info
Kubernetes control plane is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com
CoreDNS is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
~$ eksctl get cluster -A
NAME            REGION      EKSCTL CREATED
eks-marc-9587	eu-west-3	True
~$ kubectl get node
NAME                                           STATUS   ROLES    AGE     VERSION
ip-192-168-1-168.eu-west-3.compute.internal    Ready    <none>   5d22h   v1.27.16-eks-a737599
ip-192-168-45-234.eu-west-3.compute.internal   Ready    <none>   3h25m   v1.27.16-eks-a737599
ip-192-168-85-225.eu-west-3.compute.internal   Ready    <none>   5d22h   v1.27.16-eks-a737599
Clean up
Always clean EKS resources that are no longer necessary - they could be costly!
To clean the EKS cluster, resources and juju cloud, run the following commands:
juju destroy-controller $JUJU_NAME --yes --destroy-all-models --destroy-storage --force
juju remove-cloud $JUJU_NAME
List all services and then delete those that have an associated EXTERNAL-IP value (e.g. load balancers):
kubectl get svc --all-namespaces
kubectl delete svc <service-name>
Next, delete the EKS cluster (source: Deleting an Amazon EKS cluster)
eksctl delete cluster <cluster_name> --region eu-west-3 --force --disable-nodegroup-eviction
Finally, remove AWS CLI user credentials (to avoid forgetting and leaking):
rm -f ~/.aws/credentials
