Jenkins K8s
latest/stable 201 29 Sep 2025
Ubuntu 24.04 Ubuntu 22.04
latest/stable 200 29 Sep 2025
latest/edge 436 Today
latest/edge 435 Today
juju deploy jenkins-k8s
Integrations
agent
Interface: jenkins_agent_v0
Supported charms: jenkins-agent-k8s, jenkins-agent
Jenkins agents provide a way to perform tasks scheduled by the Jenkins server. Jenkins agents are used to distribute workload across multiple containers, allowing parallel execution of jobs.
Example agent integrate command:
juju relate jenkins-k8s:agent jenkins-agent-k8s:agent
To create a cross model relation with a jenkins-agent (VM) charm, create an offer from the machine model.
juju offer jenkins-agent:agent
Then, relate the offer from the k8s model where jenkins-k8s charm resides.
juju integrate jenkins-k8s:agent <controller-name>:<juju-user>/<agent-model>.jenkins-agent
An example of such command would look like the following, using a jenkins-agent deployed on a localhost LXD controller.
juju integrate jenkins-k8s:agent localhost:admin/jenkins-vm-model.jenkins-agent
logging
Interface: loki_push_api
Supported charms: loki-k8s
Logging relation provides a way to scrape logs produced from the Jenkins server charm. The Jenkins server logs are stored at /var/lib/jenkins/logs/jenkins.log. These logs are the same logs as the logs emitted to the standard output. A promtail worker is spawned and will periodically push logs to Loki.
juju integrate jenkins-k8s:logging loki-k8s:logging
metrics-endpoint
Interface: prometheus_scrape
Supported charms: prometheus-k8s
Metrics-endpoint relation allows scraping the /prometheus endpoint provided by Jenkins prometheus plugin on port 8080. The /metrics endpoint is reserved for metrics plugin, which is a dependency of prometheus plugin. The metrics are exposed in the open metrics format and will only be scraped by Prometheus once the relation becomes active. For more information about the metrics exposed, please refer to the prometheus plugin documentation.
Example metrics-endpoint integrate command:
juju integrate jenkins-k8s:metrics-endpoint prometheus-k8s:metrics-endpoint
grafana-dashboard
Interface: grafana_dashboard
Supported charms: grafana-k8s
Grafana-dashboard relation enables quick dashboard access already tailored to fit the needs of operators to monitor the charm. The template for the Grafana dashboard for jenkins-k8s charm can be found at /src/grafana_dashboards/jenkins.json. In Grafana UI, it can be found as “Jenkins: Performance and Health Overview” under the General section of the dashboard browser (/dashboards). Modifications to the dashboard can be made but will not be persisted upon restart/redeployment of the charm.
Grafana-Prometheus integrate command:
juju integrate grafana-k8s:grafana-source prometheus-k8s:grafana-source
Grafana-dashboard integrate command:
juju integrate jenkins-k8s:grafana-dashboard grafana-k8s:grafana-dashboard
Help improve this document in the forum (guidelines). Last updated 1 year, 2 months ago.
