Discourse
| latest/stable | 229 | 07 Jan 2026 | |
| latest/edge | 252 | 08 Apr 2026 | |
| latest/edge | 249 | 07 Apr 2026 |
juju deploy discourse-k8s --channel edge
How to contribute
Our documentation is hosted on the Charmhub forum to enable easy collaboration. Please use the “Help us improve this documentation” links on each documentation page to either directly change something you see that’s wrong, ask a question, or make a suggestion about a potential change in the comments section.
Our documentation is also available alongside the source code on GitHub. You may open a pull request with your documentation changes, or you can file a bug to provide constructive feedback or suggestions.
See CONTRIBUTING.md for information on contributing to the source code.
