Discourse
| latest/stable | 229 | 07 Jan 2026 | |
| latest/edge | 242 | Yesterday |
juju deploy discourse-k8s --channel edge
How to configure the container
This charm exposes several configurations to tweak the behaviour of Discourse. These can by changes by running juju config [charm_name] [configuration]=[value]. Below you can find some of the options that will allow you to modify the charm’s behaviour:
- CORS policies can be modified using the following settings:
- The developer mails can be set through
developer_emails - Throttle level protections provided by Discourse can be changed using
throttle_level
For a comprehensive list of configuration options check the configuration reference.
