Discourse
| latest/stable | 229 | 07 Jan 2026 | |
| latest/edge | 243 | Today |
juju deploy discourse-k8s --channel edge
External access required by the Charm
Depending on the configuration of the charm, the following external accesses are needed:
- Access to the PostgreSQL database (mandatory).
- Access to the S3 server is S3 is configured in the charm.
- Access to GitHub to download Promtail if the logging interface is used in the charm.
If the option “external system avatars enabled” is enabled in the admin, access to https://avatars.discourse.org is necessary.
Besides that, other services, like link previews and installing themes from a git repository
may need access to external sites to work, so allowing internet access to the Discourse instance is
recommended. In restricted environments, the model-config options juju-http-proxy, juju-https-proxy
and juju-no-proxy can be used to set up a proxy for Discourse,
see Using proxies with Charmed Kubernetes for
more information.
