Vault
| 2.0/edge | 605 | Yesterday | |
| 2.0/edge | 604 | 15 Oct 2026 | |
juju deploy vault-k8s --channel 1.16/beta
Scale
The Vault charm uses the raft backend to scale. This guide walks you through scaling Vault.
Pre-requisites
- Vault is initialised and unsealed
- The Vault charm is authorised
1. Validate that Vault is an active state
Run juju status:
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 12:52:32-04:00
vault waiting 1 vault-k8s 1.15/beta 198 10.152.183.208 no installing agent
vault/0* active idle 10.1.182.38
2. Scale Vault to 3 units
Add 2 more units:
juju add-unit vault -n 2
The new units will be sealed:
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 12:54:51-04:00
vault waiting 3 vault-k8s 1.15/beta 198 10.152.183.208 no installing agent
vault/1 blocked idle 10.1.182.51 Please unseal Vault
vault/2 blocked idle 10.1.182.34 Please unseal Vault
Set the VAULT_ADDR variable to the vault/1 unit:
export VAULT_ADDR=https://$(juju status vault/1 --format=yaml | yq '.applications.vault.units.vault/1.address'):8200; echo $VAULT_ADDR
Set the VAULT_SKIP_VERIFY to true:
export VAULT_SKIP_VERIFY=true
Unseal the the vault/1 unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
And complete the same operations for the vault/2 unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml | yq '.applications.vault.units.vault/2.address'):8200; echo $VAULT_ADDR
3. Validate that all units are part of the cluster
All units should go to the Active/Idle Juju status:
$ juju status
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 12:57:52-04:00
vault active 3 vault-k8s 1.15/beta 198 10.152.183.208 no
vault/1 active idle 10.1.182.51
vault/2 active idle 10.1.182.34
And they should all be part of the raft cluster:
$ vault operator raft list-peers
Node Address State Voter
demo-vault/0 vault-0.vault-endpoints.demo.svc.cluster.local:8201 leader true
demo-vault/1 vault-1.vault-endpoints.demo.svc.cluster.local:8201 follower true
demo-vault/2 vault-2.vault-endpoints.demo.svc.cluster.local:8201 follower true
