Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 565 07 Jul 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 592 11 Sep 2026
Ubuntu 24.04
2.0/edge 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 589 17 Aug 2026
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 577 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel 1.16/beta
  1. A Charmed Vault instance you wish to use as the unsealer. Deployed, initialized, unsealed, and authorized. See Tutorial: Getting started with Vault-K8s or Getting Started: Vault (Machine) if you’re not there yet.
  2. A second Charmed Vault instance you wish to use as the autounsealed Vault. This instance may already be initialized, unsealed, and authorized, or you may initialize it as part of this process.
export VAULT_ADDR="..."
export VAULT_TOKEN="..."
vault operator init
$ vault token create -ttl=10m
Key                  Value
token                hvs.mmMXCLNZ2X7OcqCM38WYDnoX
token_accessor       eXzWoD1ajA5YtNgfopj1DP1r
token_duration       10m
token_renewable      true
token_policies       ["root"]
identity_policies    []
policies             ["root"]
secret:cqgj49fmp25c7796r0pg
Help improve this document in the forum (guidelines). Last updated 1 year, 8 months ago.
