Vault
latest/edge 89 31 Jan 2024
Ubuntu 22.04 Ubuntu 20.04
latest/edge 9 27 Jan 2023
2.0/stable 565 07 Jul 2026
Ubuntu 24.04
2.0/candidate 590 02 Sep 2026
Ubuntu 24.04
2.0/beta 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 592 11 Sep 2026
Ubuntu 24.04
2.0/edge 590 02 Sep 2026
Ubuntu 24.04
2.0/edge 589 17 Aug 2026
Ubuntu 24.04
1.19/stable 578 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.19/beta 578 14 Jul 2026
Ubuntu 24.04
1.19/edge 579 13 Jul 2026
Ubuntu 24.04
1.19/edge 578 13 Jul 2026
Ubuntu 24.04
1.18/stable 577 14 Jul 2026
Ubuntu 24.04
Ubuntu 24.04
1.18/beta 591 10 Sep 2026
Ubuntu 24.04
1.18/edge 591 10 Sep 2026
Ubuntu 24.04
1.17/stable 354 11 Apr 2025
Ubuntu 24.04
Ubuntu 24.04
1.17/beta 383 14 Jul 2025
Ubuntu 24.04
1.17/edge 491 12 Jan 2026
Ubuntu 24.04
1.16/stable 502 20 Feb 2026
1.16/beta 502 19 Feb 2026
1.16/edge 502 19 Feb 2026
1.15/stable 248 24 Jul 2024
1.15/beta 248 24 Jul 2024
1.15/edge 248 10 Jul 2024
juju deploy vault-k8s --channel 1.16/beta
Scale
The Vault charm uses the raft backend to scale. This guide walks you through scaling Vault.
Pre-requisites
  • Vault is initialised and unsealed
  • The Vault charm is authorised
1. Validate that Vault is an active state
Run juju status:
Model  Controller          Cloud/Region        Version  SLA          Timestamp
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:52:32-04:00
App    Version  Status   Scale  Charm      Channel    Rev  Address         Exposed  Message
vault           waiting      1  vault-k8s  1.15/beta  198  10.152.183.208  no       installing agent
Unit      Workload  Agent  Address      Ports  Message
vault/0*  active    idle   10.1.182.38
2. Scale Vault to 3 units
Add 2 more units:
juju add-unit vault -n 2
The new units will be sealed:
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:54:51-04:00
vault           waiting      3  vault-k8s  1.15/beta  198  10.152.183.208  no       installing agent
vault/1   blocked   idle   10.1.182.51         Please unseal Vault
vault/2   blocked   idle   10.1.182.34         Please unseal Vault
Set the VAULT_ADDR variable to the vault/1 unit:
export VAULT_ADDR=https://$(juju status vault/1 --format=yaml |  yq '.applications.vault.units.vault/1.address'):8200; echo $VAULT_ADDR
Set the VAULT_SKIP_VERIFY to true:
export VAULT_SKIP_VERIFY=true
Unseal the the vault/1 unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
And complete the same operations for the vault/2 unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml |  yq '.applications.vault.units.vault/2.address'):8200; echo $VAULT_ADDR
3. Validate that all units are part of the cluster
All units should go to the Active/Idle Juju status:
$ juju status
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:57:52-04:00
vault           active      3  vault-k8s  1.15/beta  198  10.152.183.208  no
vault/1   active    idle   10.1.182.51
vault/2   active    idle   10.1.182.34
And they should all be part of the raft cluster:
$ vault operator raft list-peers
Node            Address                                                State       Voter
demo-vault/0    vault-0.vault-endpoints.demo.svc.cluster.local:8201    leader      true
demo-vault/1    vault-1.vault-endpoints.demo.svc.cluster.local:8201    follower    true
demo-vault/2    vault-2.vault-endpoints.demo.svc.cluster.local:8201    follower    true
Help improve this document in the forum (guidelines). Last updated 1 year, 4 months ago.
