Vault
- By Canonical Telco
latest/edge | 89 | 31 Jan 2024 | |
1.15/beta | 204 | 18 Apr 2024 | |
1.15/edge | 224 | 14 May 2024 |
juju deploy vault-k8s --channel 1.15/edge
Storage Backend
Raft is the only supported Backend in Vault charms. As you scale your Juju application, you also scale your raft cluster.
