Vault
- By Canonical Telco
latest/edge | 89 | 31 Jan 2024 | |
1.15/beta | 204 | 18 Apr 2024 | |
1.15/edge | 224 | 14 May 2024 |
juju deploy vault-k8s --channel 1.15/edge
Production blueprint
This document outlines recommendations for operating Vault in a production environment.
Infrastructure
Please follow the Vault project reference to deploy the Vault charms on hosts of appropriate size for your deployment.
High Availability
Vault should be deployed with a total of 5 units.
Observability
Vault should be integrated with Canonical Observability Stack:
- Vault should be integrated with Grafana Agent using the
cos-agent
charm relation interface. - Grafana Agent should be integrated with COS using the
loki_push_api
,prometheus_remote_write
, andgrafana_dashboard
charm relation interfaces.
Backup and Restore
Vault should be integrated with an S3 provider to conduct regular backup operations.
