Vault
| 2.0/edge | 605 | 16 Oct 2026 | |
| 2.0/edge | 604 | 15 Oct 2026 | |
juju deploy vault-k8s --channel 1.15/edge
Getting Started
In this tutorial, we will deploy Vault on Kubernetes and use it to store a very important secret.
Pre-requisites
A Ubuntu 22.04 machine with the following requirements:
- A
x86_64CPU - 8GB of RAM
- 20GB of free disk space
1. Install MicroK8s
sudo snap install microk8s --channel=1.29-strict/stable
Enable the storage and dns add-ons:
sudo microk8s enable hostpath-storage
sudo microk8s enable dns
2. Bootstrap a Juju controller
From your terminal, install Juju:
sudo snap install juju --channel=3.4/stable
Bootstrap a Juju controller:
juju bootstrap microk8s
3. Deploy Vault
Create a Juju model named demo:
juju add-model demo
Deploy the Vault K8s operator:
juju deploy vault-k8s vault --channel=1.16/edge
Deploying Vault will take several minutes, wait for the unit to be in the blocked/idle state, awaiting initialisation.
$ juju status
demo microk8s-localhost microk8s/localhost 3.4.0 unsupported 12:31:45-04:00
vault waiting 1 vault-k8s 1.15/beta 198 10.152.183.204 no installing agent
vault/0* blocked idle 10.1.182.56 Please initialize Vault
4. Set up the Vault CLI
To communicate with Vault via CLI, we need to install the Vault CLI client and set the following environment variables:
- VAULT_ADDR
- VAULT_TOKEN
- VAULT_CAPATH
Install the Vault client and yq:
sudo snap install vault
sudo snap install yq
Set the VAULT_ADDR environment variable:
export VAULT_ADDR=https://$(juju status vault/leader --format=yaml | yq '.applications.vault.address'):8200; echo $VAULT_ADDR
Extract and store Vault’s CA certificate to a vault.pem file:
cert_juju_secret_id=$(juju secrets --format=yaml | yq 'to_entries | .[] | select(.value.label == "self-signed-vault-ca-certificate") | .key'); echo $cert_juju_secret_id
juju show-secret ${cert_juju_secret_id} --reveal --format=yaml | yq '.[].content.certificate' > vault.pem
This will put the CA certificate in a file called vault.pem. Now, you can point the vault client to this file by setting the VAULT_CAPATH variable.
export VAULT_CAPATH=$(pwd)/vault.pem; echo $VAULT_CAPATH
Validate that Vault is accessible and up and running:
vault status
You should expect the following output.
$ vault status
Key Value
Seal Type shamir
Initialized false
Sealed true
Total Shares 0
Threshold 0
Unseal Progress 0/0
Unseal Nonce n/a
Version 1.15.6
Build Date n/a
Storage Type raft
HA Enabled true
5. Initialise and unseal Vault
Initialise Vault:
$ vault operator init -key-shares=1 -key-threshold=1
Unseal Key 1: NXw7vSzWOnNuNF2v5aEkQcQy/TdTuryYS9Qz3hxDS38=
Initial Root Token: hvs.0d26h3eSnlZzpUoVu49Sj64V
Vault initialized with 1 key shares and a key threshold of 1. Please securely
distribute the key shares printed above. When the Vault is re-sealed,
restarted, or stopped, you must supply at least 1 of these keys to unseal it
before it can start servicing requests.
Vault does not store the generated root key. Without at least 1 keys to
reconstruct the root key, Vault will remain permanently sealed!
It is possible to generate new unseal keys, provided you have a quorum of
existing unseal keys shares. See "vault operator rekey" for more information.
Set the VAULT_TOKEN variable using the root token:
export VAULT_TOKEN=hvs.0d26h3eSnlZzpUoVu49Sj64V
Unseal Vault using the unseal key:
vault operator unseal NXw7vSzWOnNuNF2v5aEkQcQy/TdTuryYS9Qz3hxDS38=
6. Authorise the Vault charm
Create a token:
$vault token create -ttl=10m
Key Value
token hvs.M9vfjsKfv1zOgU6QTuFJblwP
token_accessor ctfCqC3MX8vGH9G7Z3URgWsR
token_duration 10m
token_renewable true
token_policies ["root"]
identity_policies []
policies ["root"]
Add the token as a juju user secret
juju add-secret one-time-token token=hvs.0d26h3eSnlZzpUoVu49Sj64V
Grant this secret to the charm
Authorise the charm to interact with Vault using the token value from the secret:
juju run vault/leader authorize-charm secret-id="cq3rldnmp25c7bvnhim0"
You may now remove the secret
7. Create a key-value type secret
Enable the kv secret engine:
vault secrets enable -version=2 kv
Create a secret under the kv/mypasswords path with these attributes:
- key: bob
- value: 1jioaf123901jdeja
vault kv put kv/mypasswords bob=1jioaf123901jdeja
Good job, you created your first secret!
You can now retrieve it:
vault kv get kv/mypasswords
And delete it:
vault kv delete kv/mypasswords
8. Destroy the environment
Destroy the Juju controller and its models:
juju kill-controller microk8s-localhost
Uninstall all the installed packages:
sudo snap remove juju --purge
sudo snap remove yq --purge
sudo snap remove vault --purge
