Superset
| latest/stable | 39 | 30 Apr 2025 | |
| latest/edge | 102 | Yesterday | |
| 6/stable | 98 | 14 Oct 2026 | |
| 6/edge | 98 | 14 Oct 2026 | |
| 5/stable | 48 | 26 Nov 2025 | |
| 5/edge | 48 | 21 Nov 2025 |
juju deploy superset-k8s --channel 5/edge
Deploying charms from the latest/stable channel should guarantee
compatibility between charm revision and resource.
However, if you are deploying earlier revisions of the charm, use the table below as a reference for compatibility:
| Revision | Resource revision | Resource version |
| 34 | 18 | 3.1.3 |
| 33 | 18 | 3.1.3 |
| 32 | 15 | 3.1.3 |
| 31 | 14 | 2.1.0 |
You can specify both charm and resource revision in the deployment as follows:
juju deploy superset-k8s --channel=stable --revision=31 --resource superset-image=14
