Superset Operator
latest/stable 39 30 Apr 2025
latest/edge 64 09 Jun 2026
6/stable 63 05 Jun 2026
6/edge 63 05 Jun 2026
5/stable 48 26 Nov 2025
5/edge 48 21 Nov 2025
juju deploy superset-k8s --channel 5/edge
Charmed Superset supports the following feature flags:
Feature flag Default value Description
DASHBOARD_CROSS_FILTERS true Enables cross-filtering on dashboard charts.
DASHBOARD_RBAC true Enables role-based access control (RBAC) for dashboards.
EMBEDDABLE_CHARTS true Allows charts to be embedded in external websites or applications.
SCHEDULED_QUERIES true Enables the scheduling of queries to run at regular intervals.
ESTIMATE_QUERY_COST true Provides an estimate of the query cost before execution.
ENABLE_TEMPLATE_PROCESSING true Enables processing of templates within SQL queries for dynamic generation.
GLOBAL_ASYNC_QUERIES false Allows queries to run asynchronously across multiple instances globally.
You can enable, True, and disable, False, these flags using the following command:
juju config superset-k8s-ui <flag-name>=<True/False>
