Superset Operator
latest/stable 39 30 Apr 2025
latest/edge 64 09 Jun 2026
6/stable 63 05 Jun 2026
6/edge 63 05 Jun 2026
5/stable 48 26 Nov 2025
5/edge 48 21 Nov 2025
juju deploy superset-k8s --channel 5/edge
This part of the tutorial focuses on deploying PostgreSQL and Redis charms, which Superset requires to function.
Deploy a database
Charmed Superset relies on an external Charmed PostgreSQL database for storing application metadata such as users, dashboard definitions and logs. Deploy it as follows:
juju deploy postgresql-k8s --trust
You can check the deployment was successful by running juju status. You should expect an output like this:
Model           Controller           Cloud/Region        Version  SLA          Timestamp
superset-model  superset-controller  microk8s/localhost  3.5.3    unsupported  10:48:10+01:00
App             Version  Status   Scale  Charm           Channel    Rev  Address  Exposed  Message
postgresql-k8s           waiting    0/1  postgresql-k8s  14/stable  381           no       installing agent
Unit              Workload  Agent       Address  Ports  Message
postgresql-k8s/0  waiting   allocating                  installing agent
The database deployment may take some time, approximately 10 minutes, to complete. After that, all Juju components should be in active status.
Deploy a cache and message queue
Charmed Superset relies on an external Charmed Redis deployment, which acts as both a cache and message queue for Superset Celery workers. Deploy it as follows:
juju deploy redis-k8s --channel=edge
Check the deployment with juju status --watch 2s, with focus on the redis-k8s application and redis-k8s/0 unit. The deployment is completed once all units reach the active status:
superset-model  superset-controller  microk8s/localhost  3.5.3    unsupported  10:51:29+01:00
postgresql-k8s  14.12    active      1  postgresql-k8s  14/stable    381  10.152.183.243  no
redis-k8s       7.2.5    active      1  redis-k8s       latest/edge   36  10.152.183.182  no
postgresql-k8s/0*  active    idle   10.1.255.10         Primary
redis-k8s/0*       active    idle   10.1.255.21
See next: Deploy Charmed Superset
Help improve this document in the forum (guidelines). Last updated 1 year, 8 months ago.
