Charmed Spark K8s
  • Canonical | bundle
Channel Revision Published
latest/edge 4 06 Aug 2024
3.4/edge 4 06 Aug 2024
Charmed Apache Spark Solution Tutorial
The Charmed Apache Spark solution delivers Apache Spark utility client applications, that allow for simple and seamless usage of Apache Spark on Kubernetes.
This tutorial takes you through the journey of setting up necessary environment to run Charmed Apache Spark and teaches you how to run Spark jobs using both interactive shell and batch jobs. You’ll also learn how to use Charmed Apache Spark with streaming workloads and how to enable monitoring of the Apache Spark cluster.
This tutorial can be divided into the following sections:
While this tutorial intends to guide and teach you along the way, it will be most beneficial if you already have a familiarity with:
  • Basic terminal commands.
  • General familiarity with Kubernetes commands and concepts (e.g. kubectl general usage)
Let’s proceed to set up the environment needed for this tutorial in the next section.
