| 1/stable | 520 | 02 Mar 2026 | |
| 1/stable | 519 | 02 Mar 2026 | |
| 1/candidate | 520 | 27 Feb 2026 | |
| 1/candidate | 519 | 27 Feb 2026 | |
| 1/beta | 520 | 27 Feb 2026 | |
| 1/beta | 519 | 27 Feb 2026 | |
| 1/edge | 547 | 01 May 2026 | |
| 1/edge | 546 | 01 May 2026 |
juju deploy pgbouncer-k8s --channel 1/edge --trust
Releases
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release. To learn more about the different release tracks, see the Juju documentation about risk levels.
To see all releases and commits, check the Charmed PgBouncer K8s releases on GitHub.
Dependencies and supported features
For each release, this table shows:
- The PgBouncer version packaged inside
- The minimum Juju version required to reliably operate all features of the release
This charm still supports older versions of Juju 2.9. See the system requirements for more details
- Support for specific features
| Revision | PgBouncer version | Juju version | TLS encryption | COS monitoring | Minor version upgrades |
| 519, 520 | 1.21.0 |
3.6.14+ |
| 407, 408 | 1.21.0 |
3.6.1+ |
| 359, 360 | 1.21.0 |
3.4.5+ |
| 268, 269 | 1.21.0 |
3.4.5+ |
| 228, 229 | 1.21.0 |
3.4.5+ |
| 144, 145 | 1.21.0 |
3.1.8+ |
| 103 | 1.21.0 |
3.1.7+ |
| 81 | 1.21.0 |
3.1.6+ |
| 76 | 1.18.0 |
3.1.6+ |
Architecture and base
Several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
If you deploy a specific revision, you must make sure it matches your base and architecture via the tables below or with
juju info.
Release 407, 408
[details=Older releases]
Release 407, 408
Older releasesRelease 359, 360
Release 268, 269
Release 228, 229
Release 144,145
Release 103
| Revision | amd64 |
arm64 |
Ubuntu 22.04 (jammy) |
| 103 |
Release 81
| Revision | amd64 |
arm64 |
| 81 |
Release 76
| Revision | amd64 |
arm64 |
| 81 |
Note: Our release notes are an ongoing work in progress. If there is any additional information about releases that you would like to see or suggestions for other improvements, don’t hesitate to contact us on Matrix or leave a comment.
