Charm Statuses
The charm follows standard Juju applications statuses. Here you can find the expected end-users reaction on different statuses:
| Juju Status |
Message |
Expectations |
Actions |
| active |
any |
Normal charm operations |
No actions required |
| waiting |
any |
Charm is waiting for relations to be finished |
| maintenance |
any |
Charm is performing the internal maintenance (e.g. re-configuration) |
| blocked |
any |
The manual user activity is required! |
Follow the message hints (see below) |
| blocked |
waiting for backend database relation to initialise |
Normal behavior, charm needs all relations to work. |
Follow the hint to establish a proper relation. |
| error |
any |
An unhanded internal error happened |
Read the message hint. Execute juju resolve <error_unit/0> after addressing the root of the error state |
| terminated |
any |
The unit is gone and will be cleaned by Juju soon |
No actions possible |
| unknown |
any |
Juju doesn’t know the charm app/unit status. Possible reason: K8s charm termination in progress. |
Manual investigation required if status is permanent |
