23.10
23.04
22.10
22.04
21.10
21.04
20.10
20.04
| latest/edge | 1153 | 05 Jun 2026 | |
| latest/edge | 1152 | 05 Jun 2026 | |
| latest/edge | 1151 | 05 Jun 2026 | |
| latest/edge | 1150 | 05 Jun 2026 | |
| latest/edge | 201 | 19 Jun 2024 | |
| latest/edge | 108 | 12 Sep 2023 | |
| latest/edge | 62 | 10 Feb 2023 | |
| 8.0/stable | 1159 | 05 Jun 2026 | |
| 8.0/stable | 1158 | 05 Jun 2026 | |
| 8.0/stable | 1157 | 05 Jun 2026 | |
| 8.0/stable | 1156 | 05 Jun 2026 | |
| 8.0/stable | 1155 | 05 Jun 2026 | |
| 8.0/stable | 1154 | 05 Jun 2026 | |
| 8.0/stable | 1139 | 27 May 2026 | |
| 8.0/stable | 1138 | 27 May 2026 | |
| 8.0/candidate | 1134 | 27 May 2026 | |
| 8.0/candidate | 1127 | 26 May 2026 | |
| 8.0/candidate | 1126 | 26 May 2026 | |
| 8.0/candidate | 1125 | 26 May 2026 | |
| dpe/candidate | 362 | 22 Jan 2026 | |
| dpe/candidate | 1093 | 22 Jan 2026 | |
| dpe/candidate | 1091 | 22 Jan 2026 | |
| dpe/candidate | 1092 | 22 Jan 2026 | |
| dpe/beta | 362 | 22 Jan 2026 | |
| dpe/beta | 1093 | 22 Jan 2026 | |
| dpe/beta | 1091 | 22 Jan 2026 | |
| dpe/beta | 1092 | 22 Jan 2026 | |
| dpe/edge | 1149 | 03 Jun 2026 | |
| dpe/edge | 1148 | 03 Jun 2026 | |
| dpe/edge | 1147 | 03 Jun 2026 | |
| dpe/edge | 362 | 31 Mar 2025 | |
| 8.4/edge | 1099 | 17 Feb 2026 | |
| 8.4/edge | 1098 | 17 Feb 2026 | |
| 8.4/edge | 1097 | 17 Feb 2026 | |
| 8.0.19/stable | 26 | 05 May 2022 | |
| 8.0.19/edge | 26 | 05 May 2022 | |
| 8.0.19/edge | 15 | 26 Apr 2022 |
juju deploy mysql-router --channel dpe/edge
Juju version
The charm supports both Juju 2.9 LTS and Juju 3.1.
The minimum supported Juju versions are:
- 2.9.32+
- 3.1.7+ (Juju secrets refactored/stabilized in Juju 3.1.7)
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on SNAP “charmed-mysql”, which is currently available for amd64 and arm64 only! Please contact us if you are interested in new architecture!
Charmed MySQL requirements
- Please also keep in mind “Charmed MySQL” requirements.
