Charmed MySQL Router
| latest/edge | 256 | 16 Oct 2024 | |
| latest/edge | 255 | 16 Oct 2024 | |
| latest/edge | 254 | 16 Oct 2024 | |
| latest/edge | 253 | 16 Oct 2024 | |
| latest/edge | 201 | 19 Jun 2024 | |
| latest/edge | 108 | 12 Sep 2023 | |
| latest/edge | 62 | 10 Feb 2023 | |
| 8.0/stable | 257 | 17 Oct 2024 | |
| dpe/candidate | 356 | 31 Mar 2025 | |
| dpe/candidate | 355 | 31 Mar 2025 | |
| dpe/candidate | 354 | 31 Mar 2025 | |
| dpe/beta | 356 | 24 Mar 2025 | |
| dpe/beta | 355 | 24 Mar 2025 | |
| dpe/beta | 354 | 24 Mar 2025 | |
| dpe/edge | 1093 | 09 Jan 2026 | |
| dpe/edge | 1092 | 09 Jan 2026 | |
| dpe/edge | 1091 | 09 Jan 2026 | |
| dpe/edge | 362 | 31 Mar 2025 | |
| 8.0.19/stable | 26 | 05 May 2022 | |
| 8.0.19/edge | 26 | 05 May 2022 | |
| 8.0.19/edge | 15 | 26 Apr 2022 |
juju deploy mysql-router --channel dpe/edge
Note: All commands are written for juju >= v3.0
How to enable monitoring with COS and Grafana
This guide goes over the steps to integrate your MySQL Router deployment with COS to enable monitoring in Grafana.
To learn about Alert Rules, see Charmed MySQL > How to enable COS Alert Rules.
- Deployed Charmed MySQL and Charmed MySQL Router operators
- A deployed ‘cos-lite’ bundle in a Kubernetes environment
- Offer interfaces via the COS controller
- Consume offers via the MySQL Router model
- Deploy and integrate Grafana
- Connect to the Grafana web interface
First, we will switch to the COS K8s environment and offer COS interfaces to be cross-model integrated with the Charmed MySQLRouter VM model.
To switch to the Kubernetes controller for the COS model, run
juju switch <k8s_controller>:<cos_model_name>
To offer the COS interfaces, run
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Next, we will switch to the Charmed MySQL Router model, find offers, and consume them.
We are currently on the Kubernetes controller for the COS model. To switch to the MySQL Router model, run
juju switch <machine_controller_name>:<mysql_router_model_name>
Display a list of available interfaces with the following command:
juju find-offers <k8s_controller>: # Do not miss ':' here
In the sample output below, k8s is the k8s controller name and cos is the model where cos-lite has been deployed:
Store URL Access Interfaces
k8s admin/cos.grafana admin grafana_dashboard:grafana-dashboard
k8s admin/cos.loki admin loki_push_api:logging
k8s admin/cos.prometheus admin prometheus_remote_write:receive-remote-write
To consume offers to be reachable in the current model, run
juju consume k8s:admin/cos.grafana
juju consume k8s:admin/cos.loki
juju consume k8s:admin/cos.prometheus
First, deploy grafana-agent and integrate it with the principal application for the subordinate MySQL Router app <client_application>:
juju deploy grafana-agent
juju integrate <client_application> grafana-agent
Integrate (previously known as “relate”) grafana-agent with the COS interfaces:
juju integrate grafana-agent mysql-router:cos-agent
juju integrate grafana-agent grafana
juju integrate grafana-agent loki
juju integrate grafana-agent prometheus
After this is complete, Grafana will show the new dashboards MySQLRouter Exporter and allows access for Charmed MySQL Router logs on Loki.
Example of juju status on the Charmed MySQL Router VM model:
ubuntu@localhost:~$ juju status
database lxd localhost/localhost 3.1.8 unsupported 12:34:26Z
SAAS Status Store URL
grafana active k8s admin/cos.grafana
loki active k8s admin/cos.loki
prometheus active k8s admin/cos.prometheus
grafana-agent active 1 grafana-agent stable 65 no
mysql 8.0.34-0ubun... active 1 mysql 8.0/stable 196 no
mysql-router 8.0.36-0ubun... active 1 mysql-router dpe/edge 153 no
mysql-test-app 0.0.2 active 1 mysql-test-app stable 36 no
mysql-test-app/0* active idle 1 10.205.193.82
grafana-agent/0* active idle 10.205.193.82
mysql-router/0* active idle 10.205.193.82
mysql/0* active idle 0 10.205.193.13 3306,33060/tcp Primary
0 started 10.205.193.13 juju-65afbd-0 ubuntu@22.04 Running
1 started 10.205.193.82 juju-65afbd-1 ubuntu@22.04 Running
Example of juju status on the COS K8s model:
cos k8s microk8s/localhost 3.1.8 unsupported 20:29:12Z
alertmanager 0.27.0 active 1 alertmanager-k8s stable 106 10.152.183.197 no
catalogue active 1 catalogue-k8s stable 33 10.152.183.38 no
grafana 9.5.3 active 1 grafana-k8s stable 106 10.152.183.238 no
loki 2.9.4 active 1 loki-k8s stable 124 10.152.183.84 no
prometheus 2.49.1 active 1 prometheus-k8s stable 171 10.152.183.182 no
Connect to Grafana web interface
To connect to the Grafana web interface, follow the Browse dashboards section of the MicroK8s “Getting started” guide.
juju run grafana/leader get-admin-password --model <k8s_controller>:<cos_model_name>
